4x4 engine into 2wd shell
Old Jul 17, 2013 | 01:29 PM
jld0211's Avatar
jld0211
Default 4x4 engine into 2wd shell
Hi ive got a saph 2wd shell but bought a 4x 4 engine to go in it apart from the sump what else do I need to change on it thanks jay
Old Jul 17, 2013 | 02:00 PM
Cilly-jey's Avatar
Cilly-jey
Think u need different mounts. I'm doing the same and changed the mounts 2 2wd also think they use a different gear box mount. Don't no mind you as I haven't got that far yet
Old Jul 18, 2013 | 11:48 AM
tonyRS's Avatar
tonyRS
What way are you doing this mate? Just the engine? Or are you going 4x4 running gear?
Old Jul 19, 2013 | 08:15 PM
jld0211's Avatar
jld0211
Just the engine
Old Jul 20, 2013 | 05:34 AM
cossie daz's Avatar
cossie daz
If you have a t5 gearbox , 2wd engine mounts and arms will fit straight in .
If your car is a 2wd Cossie then straight in .
Old Jul 22, 2013 | 12:43 PM
cossiedad's Avatar
cossiedad
Also bear in mind the thermostat housing is different, and as such the hoses are different too. You will need to change either the housing or the hoses and rad pipe.
An alteration needs to be made to the coolant temp switch as it's in a different place on the 4x4 head (extend the wiring).
And the oil feed to the turbo comes out the exhaust side of the 4x4 head so either blank it off and use the block feed or you need the 4x4 oil feed pipe.
And the oil filter housing location is different as 4x4 have the remote arm that 2wd don't have.
Small differences but they will cause an issue if not thought about before putting it in place.
Hope this helps.
cheeRS
jason_nike
Aug 18, 2019 10:53 AM
MARKYMARKONE
Aug 20, 2015 12:55 PM
lockie
Jul 31, 2015 10:03 PM
Old ford
Jul 31, 2015 06:50 AM
