Ford Range This section is for other models in the Ford range.
Sierra 2.0i DOHC performance upgrade suggestions?
Old Jul 16, 2013 | 08:34 PM
Carnie's Avatar
Carnie
Person
Exclamation Sierra 2.0i DOHC performance upgrade suggestions?
Hi, new guy here
So I recently inherited an old 91 sierra that has been in the family longer than me. Amazed with the reliability, after sitting still through 2 winters it managed to start on the first try!
Currently the engine produces about 110-120bhp, how could I make this number slightly bigger?
not looking for anything crazy, just add a fewty bhp
Currently in the car resides an old N9E 8v 2.0i DOHC engine, replace or upgrade, maybe turbo?
Ive heard that engine conversions are popular with these cars, what would you guys suggest for my particular model? A pinto, zetec, duratec??
Any help would be appreciated
Old Jul 17, 2013 | 06:12 PM
johnandhissaffy's Avatar
johnandhissaffy
white fords look best
pinto it then turbo it thats what im doing to mine
Old Jul 17, 2013 | 06:24 PM
Carnie's Avatar
Carnie
Person
Cheers, which pinto would give some nice power/be easy to install though?
Old Jul 17, 2013 | 07:56 PM
doga-ot's Avatar
doga-ot
2 ltr pinto
Old Jul 18, 2013 | 11:18 AM
johnandhissaffy
2.0 efi pinto 205 block then keep mt75 gearbox as its stronger than type 9 then save up buy some yb conrods ,yb pistons new bearings sort out a turbo manifold garrett t3 turbo will be ok then ignition stuff and fueling system preety much thats it you can even turbo a pinto with std internals up to i think its about 190bhp witch is a lot of difference as most on here will tell ya 20 bhp difference makes a lot when doing a budget build
and installing it it will fit straight onto the mounts you have so all good only thing youll need to change will be possibly power steering rack as most pintos had non power steering but you can find a pinto with power steering iv opted to not have it im going to try out a quick rack instead
Old Jul 24, 2013 | 08:25 PM
Carnie's Avatar
Carnie
Person
Ok seems straightforward, can I just lob the pinto in or what ECU/ignition trouble can I expect? Is there a tut anywhere? Also what mpg can i expect with that setup?
Old Aug 25, 2013 | 12:41 PM
If its got a cat remove it. This will free up some power.It did to my 2ltr dohc sierra I owned years ago.
mike elsome
Sep 14, 2015 04:08 PM
focus2351
Sep 9, 2015 09:33 PM
mike elsome
Ford Range
Sep 9, 2015 05:05 PM
routemaster
Sep 7, 2015 05:27 PM
Adam Graham
Sep 6, 2015 06:04 AM
