Couple of saph trim pieces
I'm after the 2 small almost triangle shaped pieces of cloth that clip to the rear panel just behind the rear seat and side pod, in dark cloth
I'm also after a 2wd dark plastic lower centre console trim piece, it goes under the black plastic arm rest tower and all the way to the heater box and had separate black plastic window switch holder, must be mint with no breaks to the screw holes
Finally I'm after the black square plastic part the clamps the inner gear gaitor to the gearbox tunnel
Someone must have these laying around please get in touch
07746595866 or pm me
deathrider666
Sep 28, 2015 06:12 PM
