I want to run my stack dash speed impulse off my prop shaft and I need to input the crown wheel (ring) teeth and also pinion teeth.....it is a standard 4x4 Sierra Cosworth box and engine but as it is in my 205 pug I don't know how to find this...help appreciated.
No as I have 16 inch alloys on the Pug 205. I was looking to mount near the brakes but it says to keep away from sources of heat and wasn't sure what to trigger it off?
Mike rainbird and stack suggested making a bracket to mount off the abs mount and trigger on the 4 wheel bolts.....so I fired up the welder and made up a bracket....speedo now works!
