CVH and Type 9
Old Jul 8, 2013 | 12:13 PM
canis's Avatar
canis
Tinkerer
Default CVH and Type 9
Hi guys, quick question if you don't mind ...
My Type 9 gearbox (marked with an A on the side), it's bellhousing doesn't match the rear face of my CVH engine. Indeed, without removing anything I can actually see the flywheel. That can't be right, surely?
Shoudln't there be some sort of cover or plate for this? I mean - what if a kitten climbed in!! *shudder*
Joking aside, I've removed the gearbox to replace the clutch, and I'm concerned that while driving oil/water/dirt will enter the bellhousing and damage the new friction surfaces.
I've got another question, if you also don't mind ...
While probing around with the flywheel, there's some loose stuff in it's hub, and with a little finger was able to pull out some things that looked like broken pencil leads. I don't /think/ it loses any oil through the oil seal, so what might this be?
Much obliged.
~canis
Old Jul 8, 2013 | 01:01 PM
Paul_RS's Avatar
Paul_RS
You can see the flywheel on the likes of RS turbos. There should be a cover plate, but it's quite often missing.
Old Jul 8, 2013 | 02:00 PM
canis's Avatar
canis
Tinkerer
Cheers mate, I'll worry a little less about it then.
Old Jul 8, 2013 | 07:41 PM
jamie's's Avatar
jamie's
the pensil leds?
could it be the rollers out a roller bearing thats broke up?
spigot bearing maybe
Old Jul 9, 2013 | 10:28 AM
canis's Avatar
canis
Tinkerer
Thanks Jamie's (plural? are you many?) that's what i'm worried about, they do look like something out of some kind of bearing - but what? I thought this was simply the end of the crankshaft. I've taken some pictures, I'd appreciate your perusal, hopefully you (or someone) can identify what might have broken.
In here:
closer:
"Pencil leads" (as it were):
And if you know anyone who does palm readings:
What's your take on this?
Last edited by canis; Jul 9, 2013 at 10:32 AM. Reason: The 'helpful' editor tried to 'help' me ...
Old Jul 9, 2013 | 10:36 AM
liam-rst's Avatar
liam-rst
shit happens
Looks like the inside of an old bearing to me, possibly thrust?
Old Jul 9, 2013 | 10:37 AM
liam-rst's Avatar
liam-rst
shit happens
saying that looks a bit small for thrust
Old Jul 9, 2013 | 08:12 PM
jamie's's Avatar
jamie's
spigot bearing in the end of the crankshaft
Old Jul 9, 2013 | 08:52 PM
RSargie's Avatar
RSargie
Correct!!
You need to replace that, before refitting the gear box.
Also you need to make sure the main shaft, of the gearbox slides effortlessly into it. When refitting the box. As that bearing is a support for the main shaft. It is very easy to catch the end of the needle roller bearings and break them.
Old Jul 10, 2013 | 07:43 AM
canis's Avatar
canis
Tinkerer
Rats. I put the gearbox back on yesterday. Oh well - looks like it's coming off again.
mk3ste
Oct 17, 2021 10:09 AM
chowfornow
14
Jan 5, 2019 09:01 PM
Nov 1, 2015 06:53 PM
Turbo1994
Ford Escort RS Cosworth
Oct 17, 2015 10:32 PM
