Misfiring 3dr
Old Jul 3, 2013 | 09:01 AM
martynhomer01's Avatar
martynhomer01
Default Misfiring 3dr
Hi guys, my 3dr keeps misfiring as its coming under load. It's only done 85000 miles, original engine, and I have out new iridium plugs in it, gapped from 0.6 mm down to 0.5mm.
The car is running stage 3, with t3 turbo and still has the antiquated dizzy and rotor arm system. I have a group a coil, with magnecor leads, new dizzy cap and rotor arm, but it still keep missing , only under load. Idle is sweet.
Been looking at the wasted spark system that msd has to offer, but does it really work? £400 seems a lot to me, but if it cures it, then I will be well chuffed.
Old Jul 3, 2013 | 10:22 AM
scholes's Avatar
scholes
I've put msd wasted spark on mine and its great never had any issues it's a great upgrade
Old Jul 3, 2013 | 10:45 AM
Harris.'s Avatar
Harris.
Crank sensor, phase sensor !
Old Jul 3, 2013 | 08:53 PM
L1bpb's Avatar
L1bpb
Moonstone 3dr
Put some 071 ford plugs gapped to 0.6 new phase sensor gapped, check fuel filter
Old Jul 3, 2013 | 09:30 PM
daz1968's Avatar
daz1968
Wasted spark is good I have it on mine but it won't solve an undermining problem, a group a coil and good condition standard set up should work ok, I would try some 071 plugs gapped at 0.6 and check all sensors and gaps first, nothing worse than spending all that money and still having problem. But I always find the symptoms you have is down to plugs or plug gaps.
Old Jul 4, 2013 | 12:39 AM
SS1's Avatar
SS1
Put some 071 ford plugs in
Iridium don't fuck with the gaps
And they hate overfuelling
Sierrasideways
Oct 8, 2015 06:37 PM
martynhomer01
Oct 1, 2015 12:05 AM
IainRS1700T
Sep 25, 2015 06:44 AM
Brickhouse
Sep 21, 2015 11:00 AM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
