Cosworth 2.2ltr alloy block 800bhp engine
Old Jun 27, 2013 | 09:16 PM
jacko996's Avatar
jacko996
Default Cosworth 2.2ltr alloy block 800bhp engine
This engine is as new, only had 3 hours running on brand new components
It is currently at SCS having a once over to check everything is spot on before sale
Will come complete with T6 2000 ecu, full dry sump system. and brand new race spec engine loom
Alloy block is approx 20kg lighter than standard block
SCS built YB, New Smith & Jones alloy tall block, 2.2 capacity, 10 long studs, oil spray jets, Extra long Arrow con rods, custom CP pistons with valve cut-outs, Arrow forged stroker crankshaft, Dry sump system with pace pump, heavily ported BIG valve head by Nick Waples, WRC multi layer head gasket, custom turbo speced by SCS built by CR Turbos, custom inlet manifold designed and built by SCS, SCS spec high lift camshafts, Solid lifters, Isky double valve springs, 8 grey injectors, Pectel T6 2000 engine management.
18K
Harvey at SCS will be happy to answer any questions you may have
Cheers dave
Old Aug 6, 2013 | 08:32 PM
jacko996's Avatar
jacko996
Just priced this up as a new builds at 25k + vat so a bargin to be had by someone :icon_smile:
original
Apr 28, 2026 05:20 PM
big_Rad
Sep 15, 2017 09:36 AM
Aug 14, 2015 07:29 AM
Zoggon
Aug 10, 2015 10:39 AM
Old ford
Jul 31, 2015 06:50 AM
