Tremec t56 6speed
Old Jun 27, 2013 | 12:05 PM
turnover's Avatar
turnover
Default Tremec t56 6speed
T56 6 speed from dodge viper so has the higher torque capacity and larger rear output shaft,has adaptor plate and Chevy bellhousing ,but with this adaptor you could fit 90% of bellhousings if it wasn't going behind Chevy ,£ 1000 ono
Old Jun 27, 2013 | 12:31 PM
Cosnada's Avatar
Cosnada
Hi Terry,
How does this compare to the TKO600?
Cheers.
Old Jun 27, 2013 | 01:13 PM
turnover's Avatar
turnover
Basically the gear ratios are same as Cossie t5 1 to 4 5th is slightly taller and 6 gear is very low as with most t56 boxs so at 80 mph you'd probably be only reving at 2000 rpm in 6th gear depending on your final drive,very very strong box and shifts nice and positive same as t5,there a lot of v8s supra,s and vipers etc using them with 1000 hp,plus the t56 is stronger and shifts better at higher rpm
Old Jun 28, 2013 | 09:56 AM
cossynut2's Avatar
cossynut2
10 Year Member
Hi Turnover, what exactly would be needed to fit your Tremec gearbox to a 2wd Sapphire Cosworth? I already have a modified bellhousing for the hydraulic clutch conversion which has recently been done.
Old Jun 28, 2013 | 10:17 AM
turnover's Avatar
turnover
Pmd mate
IainRS1700T
Sep 25, 2015 06:44 AM
f6cus
22
Oct 5, 2009 05:21 PM
abdr500
Feb 10, 2009 11:26 PM
mudlark
Jan 22, 2008 08:11 PM
abdr500
Jul 29, 2007 10:24 PM
