2wd and 4x4 abs sensors, same?
Old Jun 24, 2013 | 08:09 AM
peteh's Avatar
peteh
Default 2wd and 4x4 abs sensors, same?
Just wanted a defo answer, are the fronts the same?
Just different colour coding I believe.
Cheers, pete
Old Jun 24, 2013 | 09:55 AM
doga-ot's Avatar
doga-ot
And are the abs ecu's the same
Old Jun 24, 2013 | 06:17 PM
peteh's Avatar
peteh
anybody?
Old Jun 24, 2013 | 06:19 PM
MONSTER's Avatar
MONSTER
As far as I'm aware the Saff ones are the same, not sure on 3dr though
Escos are the same sensor as Saff 4x4 but they have a different connector
Old Jun 24, 2013 | 08:46 PM
JFB Tech's Avatar
JFB Tech
Not entirely sane
ECUs are different, the 4x4 one has a big 4x4 logo on it, the plugs are the same but the keyway pins are in a different position so you can't fit the wrong one.
Old Jun 24, 2013 | 08:58 PM
martysmartie's Avatar
martysmartie
3DR and Saph are the same (As is any other ABS model or Granada), I am not positive but believe the 4x4's to be the same as well.
4x4 braking system is different though, not just in terms of stoppers, the master cylinder is different, and as said, I believe the ECU is different as well.
Martin
Old Jun 24, 2013 | 09:15 PM
zetec69's Avatar
zetec69
Yep ECU's & master cylinder/servo definately different
Old Jun 25, 2013 | 05:20 PM
peteh's Avatar
peteh
so nobody has actually put a 4x4 one on their 2wd and it worked?
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
15
Oct 7, 2015 03:43 PM
FlashRS
13
Aug 31, 2015 06:02 PM
