garage sort out
loads of 3 door cosworth bits
bbs split rims with tyres £2000
500 bhp rs500 engine freshly built £6000
konis with springs 2 sets £300 or £125
loads of switches and trim bits
rear arms £25 each
rear subframe£50
new and used headlights cibie and lucas £250 to £45
new and used rear lights £125 or £40
rear bulb holders £20
2wd rear calipers recon £120
collins plug leads new £40
new 2wd exhaust manifold £200
3 door mirrors £40
3 door glass rear quarters and front £100
rs500 loom £175
ecus £100
oil cooler £25
new ford sapp expansion bottle £45
tps sensors £45
3 bar map sensors £45
all chrome bits like fuse box abs pump coil etc new
4wd alternator £45
amal valves £20
3 rads and fans £125
inlet manifolds £40
new timing belts £20
brand new ford bulkhead panel for a sapphire £100
wiper linkage and motor as new £100
just call me on 07883011989 i have other parts
rear arms £25 each
rear subframe£50
3 door mirrors £40
rs500 loom £175
ecus £100
oil cooler £25
tps sensors £45
4wd alternator £45
amal valves £20
inlet manifolds £40
rsguy
44
Sep 29, 2015 03:29 PM
PRO-LINE MOTORSPORT
Sep 28, 2015 09:54 PM
