2wd temp query
Old Jun 19, 2013 | 08:06 PM
johnnycortina's Avatar
johnnycortina
Default 2wd temp query
I put my 2wd sapphire back to original 2wd header tank recently - it had a 4wd one when I bought it. Temp was fine before change. Now I am getting temp gauge going up near red when driving. It may drop back for a while and then back up. Cannot understand whats up with it - as its a simple change. I lost very little water from system when changing it over. Any help / advice appreciated.
Old Jun 19, 2013 | 10:22 PM
Danny555's Avatar
Danny555
Check you have not got a air lock.
Do your fans cut in?
it won't hurt to pull the stat housing out and check your thermostat.
run it to temp and feel around the radiator to see if it's the same temp all over.
If all is ok then pull the pump out and check to see if it's ok.
Old Jun 20, 2013 | 08:29 PM
johnnycortina
What is the best method to bleed air from system or avoid an air lock when refilling system?
Old Jun 21, 2013 | 06:12 AM
William MK2 Cosworth's Avatar
patience.....
anyway, the return from the turbo should be the highest point in the engine, check you have water there, and when the engine is running if the water flows through.
I have seen on a peugeot 106 I once had that the temp was fine, but once i changed the water the thermostat got stuck afterwards
Old Jun 21, 2013 | 03:34 PM
johnnycortina
Cheers all - new thermostat ordered. See how she goes then.
Mark RS
Oct 12, 2015 06:01 AM
mark r
Sep 29, 2015 07:27 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
