I finally got something done this weekend.
Old Jun 16, 2013 | 03:14 PM
Jasu's Avatar
Jasu
Default I finally got something done this weekend.
Well, almost together.
Oil pan gasket problem. Oil pan is bent when welded. Had to take 1mm off the surface. Now the gasket is too thin.
Old Jun 16, 2013 | 04:06 PM
LHD220Turbo's Avatar
LHD220Turbo
nice & clean!
what power you expecting?
Old Jun 16, 2013 | 04:21 PM
Jasu's Avatar
Jasu
Thanks.
I would be happy to 500/500, but 450/450 may be closer to the truth.
Old Jun 16, 2013 | 04:43 PM
LHD220Turbo
either way, 450/450 is a very quick car
i see you have individual coil packs too!
Old Jun 16, 2013 | 11:39 PM
kosienutter's Avatar
kosienutter
Last Time, Get Off PF FFS
That looks swaaeeeeet
Old Jun 17, 2013 | 07:17 PM
Caddyshack's Avatar
Caddyshack
10 Year Member
Simply stunning....makes me want to pull my engine out and do that to it....the looks alone have to be worth 100 bhp lol
Old Jun 17, 2013 | 07:51 PM
Jasu's Avatar
Jasu
Thanks.
I want to keep all "reasonably" simple and easily repairable. And silver is a good color, leaks can be found easily. (It is YB, it will leak)
Does anyone have a good idea that how could I fix that sump gasket problem?
1mm gasket shape shim + 2 gaskets?
Thicker gasket somewhere?
mondeomark
Sep 28, 2015 06:28 AM
