Wheels and Tyres Wheels and Tyres for all Ford's
Tyres does anyone know?????
Old Jun 14, 2013 | 10:26 PM
doga-ot's Avatar
doga-ot
Default Tyres does anyone know?????
I have a set of lattice wheels on my saph which was 4x4 so tyres are 205/50/1.
Rear are now bald and car is no longer 4x4 it is now back to how it should be 2wd, I now need to replace rear tyres for time being until I find a set of 17's I want.
My question is what is the widest tyres I can run on these alloys bearing in mind I need to keep them ???/50/15(for rear) i think they are 7j
When I run 17's I will be running 225/35-40/17 on back and 215/35-40/17 on front
Old Jun 14, 2013 | 10:57 PM
doga-ot's Avatar
doga-ot
Anyone
Old Jun 15, 2013 | 07:16 AM
skinnarbi's Avatar
skinnarbi
Tyres - It's What I Do
The problem is you would need either a 215/45r15 or a 225/40r15 the problem is after a quick search I can't find availability in either size, and if they were they would be considerably more expensive than 205/50r15. I'd stick with 205's until you change the wheels.
Regards
Matt
Old Jun 22, 2013 | 12:11 AM
Mondego's Avatar
Mondego
Another issue to consider is, in order to maintain rolling radius, or wheel diameter, the profile needs to change in direct ratio to the tyre width. Since the profile is given as a percentage of the width. e.g, a tyre with profile 50 (%) with a tread width of 200, would mean the profile equates to 100mm (half, or 50% of the width). So changing one and not the other will result in a change in wheel diameter/rolling radius.
Use a tyre size calculator to ease the headache:
http://www.discovery2.co.uk/tyresize.html
Old Jun 22, 2013 | 12:14 AM
Mondego's Avatar
Mondego
Oops, i just realised there is a trye size calculator right here on passionford.
Old Jun 22, 2013 | 05:00 PM
skinnarbi's Avatar
skinnarbi
As I mentioned above. Those tyre size calculators are good but sometimes as in this case to keep the rolling radius right you end up with a size that either doesn't exist or is so uncommon the price becomes uneconomical especially as its only temporary until new wheels are purchased
Regards
Matt
Old Jun 22, 2013 | 05:02 PM
doga-ot's Avatar
doga-ot
just put new 205/50/15 on today till I get my hocks
Old Jun 22, 2013 | 05:58 PM
Mondego's Avatar
Mondego
@Wes: Good job as they're temp.
@Matt: Agreed. I use tyre calculators, but like you said, I dont rely on the result being final.
Old Jun 22, 2013 | 06:13 PM
doga-ot's Avatar
doga-ot
When I get my 17's (Hock's) i'm going to run 235/40/17 rear, 215/40/17 front on et40 or rear 225/40/17 and front 215/40/17
Old Jun 22, 2013 | 07:58 PM
Mondego's Avatar
Mondego
Should look sweet. Bigger the better!
Old Jun 22, 2013 | 08:23 PM
doga-ot's Avatar
doga-ot
Dnt know how wide I can go as I have koni adjustable's so not sure if 235/40/17 will rub
Old Jun 22, 2013 | 10:21 PM
Mondego's Avatar
Mondego
225/235, it's only an extra 10mm (5mm on either side of the tyre)
You should be OK, but either will look great....
Old Jun 22, 2013 | 11:30 PM
skinnarbi's Avatar
skinnarbi
I had some 245/40r17 on my old saph with 10mm spacers and longer studs and they only rubbed over big bumps and if I had passengers in the back. Only put them on as I picked them up part worn from work as a bloke with a merc wanted a set of 4 even though his rears were still at 5mm
Old Jun 23, 2013 | 12:10 AM
Mondego's Avatar
Mondego
Serious width. Nice.
Although, Doga's Koni's probably have the ability to sit him pretty low if he wishes...
Mark RS
Mar 5, 2021 06:08 PM
tankybaby66
Feb 6, 2016 02:24 PM
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
Alloy wheels and ICE for sale
Sep 28, 2015 06:19 PM
