getting started with a Sierra
Old Jun 14, 2013 | 07:00 AM
laktix's Avatar
laktix
Default getting started with a Sierra
Hello guys, I bought a 92 Sierra 1.8TD with pretty high miles and it was standing for a few years but the car looks like an amazing first car project, the owner was kind enough to say that t he car had trouble starting at winter due to low compression, could someone who knows a bit more then me about that engine tell me if they have some usual "illneses" that would cause that, and should I change to make sure that the car will be reliable in the future?
Old Jun 14, 2013 | 10:08 AM
Brendan's Avatar
Brendan
struggling with reality
Low compression could be head gasket or piston rings!
not starting in the winter sounds like glow plugs!
Old Jun 14, 2013 | 10:28 AM
I would be checking to see if the glow plugs are working first.
Old Jun 14, 2013 | 04:07 PM
laktix's Avatar
laktix
Glow plugs were my initial thought as well, but it could still be caused because of low compression (piston rings/worn valve sleeves)?
Old Jun 14, 2013 | 04:32 PM
Rax's Avatar
Rax
I have had two 1.8td,one hatch and a sapphire also non turbo escort.Lazy bloody things but a pretty good motor.One thing I found with them that was if the battery wasnt up to much they would take a while to start as they never seemed to turn over quick enough.Let the heater plugs run twice and start.
Old Jun 14, 2013 | 04:40 PM
turbofreak's Avatar
turbofreak
kris
get a compression check done.it will be the the last cilinder that has lost compression because of the heat from the turbo.some sierra's are having that trouble.you wont have the trouble in a mondeo because the engine mounted the other way.cheeRs
Old Jun 14, 2013 | 05:04 PM
laktix's Avatar
laktix
Good tip mate thanks I'll give it a shot
tomiii
12
Aug 18, 2015 08:40 PM
Vincereese
Aug 15, 2015 06:24 PM
Vincereese
Aug 11, 2015 08:44 AM
Adam-M
22
Aug 10, 2015 10:46 AM
Old ford
Jul 31, 2015 06:50 AM
