2006 TDCi Mondeo A/C fault.
Old Jun 10, 2013 | 11:17 PM
MARKTWO's Avatar
MARKTWO
Default 2006 TDCi Mondeo A/C fault.
My air-con is not working. Compressor clutch is not engaging. Removed clutch and fitted smaller shim but still no engagement. Not sure if shim is still too thick? Used smallest supplied in £8.71 Ford kit (0.87mm). Noticed outer radius of clutch face has surface rust. Should I clean that and also try a thinner shim...or try with no shim??
Old Jun 11, 2013 | 07:07 AM
foreigneRS's Avatar
foreigneRS
Testing the future
is the clutch getting a proper supply voltage? there are many reasons why a clutch wouldn't get a voltage (empty system, faulty pressure switches/sensors, relays, fuses etc).
if it is and still is not working, possibly the clutch coil has gone. it needs a proper air gap between the 2clutch faces otherwise it will drag and overheat causing bearing failure which will then chuck the belt off and make a right mess.
Old Jun 11, 2013 | 07:14 AM
Do you have plenty of air con gas in the system.If this is low the air con pump wont work.
Old Jun 11, 2013 | 10:55 AM
MARKTWO's Avatar
MARKTWO
Thanks Nick and Glenn..all good sensible points. Realized last night that if gas has gone LP switch will not allow power to compressor/clutch. Going to Kwik-fit this morning for re-gas at £49 or free if still no A/C. Thanks again, Mike.
Old Jun 11, 2013 | 05:31 PM
foreigneRS's Avatar
foreigneRS
Testing the future
if it is empty and they refill it and charge you it will be empty and not work again soon if the leak is not repaired
Old Jun 11, 2013 | 11:05 PM
MARKTWO's Avatar
MARKTWO
My view is a little more optimistic as it's claimed 10% of refrigerant permeates from car A/C system per year. My Mondeo is 7 years old therefore I am assuming it has slowly lost 70% of gas. I would think with that amount of loss the LP switch would operate and prevent clutch/compressor from being energized. Bearing in mind Mr Ford charged me £8.71 for a small selection of shims (which in reality are cheap washers) I am happy to have A/C fully restored today for 49 quid by Kwik-fit.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
wowk
Mar 30, 2021 07:49 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
The Enigma
Sep 29, 2015 10:31 AM
Sp3no
Sep 27, 2015 07:23 PM
