Rear stub axle & anti roll bar
What size is the rear anti roll on a 4x4 saph cossie?
Also are the rear stub axles and caliper carriers the same on the 2wd/4x4's or are they different between each model?
The rear arb is 18 mm on the 4x4, 16 mm on the 2wd sapph.
Caliper carriers are the same for 4x4 and 2wd. Stub shafts I'm not sure, as the 2wd uses thicker driveshafts with 108 mm flanges in stead of the 100 mm of the 4x4. But I don't know if that is on both sides of the driveshafts, or only on the diff side.
you will need the 2wd ones as they will be 108mm and not 100mm like everything else other than the 2wd cossie shafts
as in the shafts use 108mm cv joints because they are thicker so will only bolt onto the 108mm stub shafts in both the diff ends and the hub ends
