Ford Puma Discuss the Ford Puma here!
puma 1.7 zetec s temperature gauge
Old Jun 9, 2013 | 03:04 PM
mmaddick's Avatar
mmaddick
Exclamation puma 1.7 zetec s temperature gauge
hi
just a general question about my temperature gauge,
its never gone into the red and has days when it stays in the middle. the puma has had a new water pump, and i have no loss of coolant but recently the needle quite often goes right up but not into the red and comes back down almost immediately when the fan comes on, but it can keep going up and down all the time for about 20 mins when im driving.
thing is although its never gone into the red yet is this a problem or isit common especially on a hot day???
thanx for any feedback
Old Jun 9, 2013 | 03:32 PM
Straight_4_N/a's Avatar
Straight_4_N/a
Not normal.
Normal is getting to half way and staying there no matter what.
Your fans should only be kicking in if you got the engine running at the car not moving.
Sounds like you got a dicky thomastat just replace it and that will fix your problem.
Old Jun 9, 2013 | 03:57 PM
mmaddick's Avatar
mmaddick
K thanx
Old Jun 10, 2013 | 09:15 PM
mmaddick's Avatar
mmaddick
would it harm if i removed the thermostat temperarely
Old Jun 14, 2013 | 12:33 PM
cherie's Avatar
cherie
I have boobs
I's say either the thermostat or heater control valve. Can you vary the temp coming out of the air vents, or is it stuck on one (usually blood boiling hot), as that and the engine temp gauge shooting into the red are the classic symptoms.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
mk3ste
Oct 17, 2021 10:09 AM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
Mark RS
Oct 12, 2015 06:01 AM
youngben
Sep 27, 2015 09:37 PM
