door mirrors
Old Jun 7, 2013 | 04:27 PM
y4n's Avatar
y4n
Default door mirrors
Hi my electric door mirrors dont work i have changed the fuse and switch and still nothing,
Im from north shields and i will buy a few cans of beer and of your choice to come and get them working.
any takers
thanks in advance
Old Jun 7, 2013 | 06:16 PM
dojj's Avatar
dojj
Resident Wrestling Legend
it could just be the controler switch
make sure you have power to it as it's always live
pop the cover off as the switch is a bastard to get out
the good news is that ALL door mirros switches appear to have been the same across all the ford range until baout 2007 so getting another one is easy
Old Jun 7, 2013 | 06:45 PM
y4n's Avatar
y4n
Wish you were closer I need help but
I will do what you said
Old Jun 7, 2013 | 07:03 PM
dojj's Avatar
dojj
can't remember exactly, but there is a little cap and a screw underneath that holds the mirror inside cover in place, it's clipped in
remove this and get the plug off the back and see if there is power there
if there isn't then look to the wiring loom coming into the drivers door to see if there is a break in the wires there somewhere
Old Jun 8, 2013 | 11:28 PM
y4n's Avatar
y4n
ok im stuck the offer still stands i cant seem to get them to work i know the bullet connector is providing a live and there is a earth on the brown wire yet nothing happens when switch is used
please help if you are local near north shields
please i beg you whoever can get them to work
regards
y4n
Old Jun 9, 2013 | 11:09 AM
dojj's Avatar
dojj
have you followed the loom around the piller and though the door all the way to the switch?
if there is power at the main input you will have power everywhere in the system
so it's very very easy to sort
Old Jun 9, 2013 | 12:54 PM
y4n's Avatar
y4n
cheers dojj i will give it shot now
if i cant do it maccy dees or kfc is on the offer now
Old Jun 9, 2013 | 01:58 PM
y4n's Avatar
y4n
Ok dojj
ive followed the wires like you said and there isnt any breaks in the wire confirmed with multimeter ive tried quite a few switches and still nothing.
Old Jun 9, 2013 | 06:04 PM
dojj's Avatar
dojj
So you have power in the main loom?
And you have power in the door look?
And you have power in the door loom to the switch yes?
But nothing from the switch onwards?
Correct so far?
If you have tried several other confirmed working in another car switches I would then have that second car there as well to check where the power goes from the switch back into the door loom back down through the car again
It should just be a break in the main wiring which you should be able to rectify fairly easily as its all contained in the door itself
If its the main loom you can just replace individual wires but my first port of call would be to strip all the door loom out and then connect it outside the door to make checking the wires and plugs easier
You should also do a continuity check on the wires from end to end as it could be just a dry joint in the door loom
It's easy working in sierras
There should only be 5 wires in the main power loom so check that first
Old Jun 12, 2013 | 06:12 AM
y4n's Avatar
y4n
ok took all the door mirror wires and switch wires out the drivers door place it on the ground, checked wires with multimeter, then i provided a earth and power to the switch and nothing no click or anything, there must be something stupid stopping them working but cant suss it out
Old Jun 12, 2013 | 06:14 AM
y4n's Avatar
y4n
oh yeah i checked the fuse and according to the manual it controls other stuff and all the othe things work but not the mirrors
chowfornow
14
Jan 5, 2019 09:01 PM
Nov 1, 2015 06:53 PM
mpilk
Sep 27, 2015 09:21 AM
