Turbo size
Old Jun 4, 2013 | 08:52 PM
martynhomer01's Avatar
martynhomer01
Default Turbo size
Been away from the cossie scene for a long time now, but have just bought a moonstone cossie 3dr. Has 85000 miles form new and has dark greens, 3bar -31 actuator etc etc for Stage 3 setup, but the turbo is still the t3. Is it best for me to change to t34? Or should the t3 be ok? It boosts nicely, but seems to run out of "puff" after a while. Thanks guys
P.s anyone got a t34 if needed? Cheers
Old Jun 4, 2013 | 09:20 PM
Staffi's Avatar
Staffi
T3 will be fine on Greens, yes it will die top end and will at best see 300-315 bhp, i had a Stage 2 TT on my old 3dr with NMS live map peaking @ 27psi on greens etc, it was superb, made 310 bhp and 356ft/lb
PS, T34.48 would be a nice upgrade though
Old Jun 5, 2013 | 08:37 AM
martynhomer01
cheers bud
Old Jun 5, 2013 | 09:29 AM
1374lee's Avatar
1374lee
Agree with the above,t3 will be pushed to the limit,having said that depends on what boost pressure you will be running. T34 with a .48 would be much stronger and won't die out at top end of the boost range as much a a t3 plus you will get more power from the t34 turbo over the t3 obviously.
Finally with the t34 you will be able to use the full potential of the dark green 803 injectors that you have.
Thanks.Lee.
Old Jun 5, 2013 | 05:33 PM
martynhomer01
Thanks.Lee.
Cheers lee. Where u reckon the best place o get one from?
Old Jun 5, 2013 | 10:57 PM
1374lee's Avatar
1374lee
Try Vince at CR Turbos.
Thanks.Lee.
Old Jun 7, 2013 | 08:38 PM
mark r's Avatar
mark r
I have a t3 stg2 from turbo technics and its been great ,had it 5 yrs now max bhp 380 at 2 bar.
Old Jun 7, 2013 | 08:44 PM
Staffi's Avatar
Staffi
A T3 @ 380 and 5yrs @ 2 bar, can you find me one please
Yeah right, think you've missed a 4 from behind the 3 matey
Old Jun 7, 2013 | 08:52 PM
mark r's Avatar
mark r
yes that right 380,its realy a t34 with a 55ex housing from tt.im running 55lb siemens msd 380 convo chip at 2 bar.if you want 1 look at tt web site
mark
Old Jun 7, 2013 | 08:55 PM
mark r's Avatar
mark r
http://www.turbotechnics.com/docs/catalogue.pdf
Old Jun 7, 2013 | 09:15 PM
Staffi's Avatar
Staffi
mark
So it's a T34 then?
T3 CANNOT simply flow enough, won't even make 330 and if it did it'd only last aday
Matt Baxter
Sep 16, 2015 08:30 PM
lee2cossies
Aug 26, 2015 10:04 PM
muz
Aug 16, 2015 12:57 PM
marky_g
Aug 3, 2015 04:45 PM
