Main shaft MT75 Cosworth 4x4
Old Jun 1, 2013 | 09:03 AM
MalZon's Avatar
MalZon
Default Main shaft MT75 Cosworth 4x4
Is there anyone who broke the Main Shaft in a Cosworth MT75 4x4 box? How did you solve the problem?
This i my 2nd shaft i broke. Is there a replacement for the original shaft? On my 2nd shaft i did som peening for making it stronger, but obviously it didnt I really was enough.. Need something stronger now..
Got a Oppliger Semi-Cut box that works just fine, so im not so interested in a boxchange.
Regards/Jonas
Old Jun 3, 2013 | 08:42 PM
MalZon's Avatar
MalZon
Nobody?!
Regards/Jonas
Old Jul 12, 2013 | 12:08 AM
getawayracing's Avatar
getawayracing
Getaway Racing
Yeah i have a quaife synromesh/orginal gear box layinc around, need shaft tooo... Is it same as Ford Transit and other mt75 shafts on all "orginal" gear kits
Old Jul 13, 2013 | 07:23 PM
MalZon's Avatar
MalZon
Nope, Romain @ Oppliger was talking about making a stonger shaft, but hav not se any info or pics of if.
Did you crack the house of the gearbox? I did.
Mvh Jonas
Old Jul 13, 2013 | 07:31 PM
getawayracing
Getaway Racing
Default quaife
No cracks here do you have some parts?
Old Jul 13, 2013 | 08:12 PM
MalZon's Avatar
MalZon
Lucky
No sorry, buy new when it breaks..
Regards/Jonas
Old Jul 13, 2013 | 09:03 PM
dojj's Avatar
dojj
Resident Wrestling Legend
that's mot the main shaft
on the 4wd there are 4 shafts
on the 2wd there are just 3
both have input shafts
both have counter shafts
then you have the longer main shaft in the 2wd and the shorter main shaft in the 4wd
the 4th shaft is the poutput shaft which comes out of the epicyclic diff in the transfer box which is driven by the shofter main shaft int he 4wd box
from the pic you have broken the output shaft, which is an easy enough change even with the box in the car, but it's quicker to take the box out
Old Jul 13, 2013 | 09:25 PM
MalZon's Avatar
MalZon
Are you for real?!
Regards/Jonas
mk3 fiesta cosworth
Aug 23, 2015 10:31 AM
Anutternutter
Aug 21, 2015 06:07 PM
charliecosworth
Aug 19, 2015 02:00 PM
cossie4x4
Aug 14, 2015 06:29 PM
Old ford
Jul 31, 2015 06:50 AM
