Cosworth going thru plugs
Has anyone any ideas why my 4wd saff is going thru spark plugs like no tomorrow. It is running rich on idle but it is rediculious the amount of plugs i have put in it and the car aint even on the road. I know it aint ideal just starting them and not running them. The car is running stage 3. I had it at the rolling road but suffered from clutch slip so he couldna do any tweeking but was pleased with the way the car ran.
Should i look into getting a chip for the lambda or anyone any other ideas??
The annoying ginger guy
Personally I would find a tuner that can recommend you a chip and at the same time they would be able to chose the right plug with the right heat range
wheelwizardrefurbs
Sep 23, 2015 09:14 PM
Aug 14, 2015 07:29 AM
