2.0 dohc brakes and steering rack question
Old May 29, 2013 | 11:27 PM
john-saff's Avatar
john-saff
Default 2.0 dohc brakes and steering rack question
ive got the chance of buy 2wd cosworth calipers discs and pads at humble money question is do they fit straight onto my 2.0 dohc hubs or have i got to change hubs aswell ? also my sierra recently went in for nct and there is play in the rack up and down the way and the part that goes upto the steering wheel lifts up out of the rack a when locking left or right one man told me it was spring loaded the other said it was dangerous wear which one is it ? and can they be refurbed or is it time for another rack ? cheers
Old May 30, 2013 | 07:02 AM
doga-ot's Avatar
doga-ot
Could be worn steering coloumn bush and worn steering coupling nuckle which can still be bought new will give u a link when i'm home of where from
Old May 30, 2013 | 09:25 AM
john-saff's Avatar
john-saff
thanks
Old May 30, 2013 | 09:56 AM
DixieTheKid's Avatar
DixieTheKid
Pick-up P100 Power!
If that's the case I have one for a dohc down the shed.
Old May 30, 2013 | 10:03 AM
dojj's Avatar
dojj
Resident Wrestling Legend
Brakes will fit if you tap the hubs
The Cossie stuff boots TO the hub whereas the normal stuff boots THROUGH the hub
The rack issues are 2 separate things, the column bush is Ł4 and 15 minutes
It's the rest of your description that is a little confusing
Old May 30, 2013 | 02:45 PM
doga-ot's Avatar
doga-ot
as promised:
http://www.retrofordinternational.co...int-2142-p.asp
Old May 30, 2013 | 10:55 PM
leedsrhinos126's Avatar
leedsrhinos126
Sorry to hi-jack
just bought column bush kit, how does it fit ?
Many thanks
Old May 31, 2013 | 08:01 AM
dojj's Avatar
dojj
I'll do a thread about it and hopefully one of the mode will sticky it
It's very very easy
Old May 31, 2013 | 08:23 AM
doga-ot's Avatar
doga-ot
It's very very easy
As dojj says its easy if you have kids they would even be able to do it
Old May 31, 2013 | 08:32 AM
Yeh its easy to do.Before i changed mine i had a jubilee clip around the bush to stop it from coming out.
yatta
May 21, 2016 10:31 PM
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Adam Graham
Sep 6, 2015 06:04 AM
cossirob
Sep 3, 2015 09:17 PM
