Tremec tko 600 where from ???
Old May 29, 2013 | 08:33 PM
Alg1k's Avatar
Alg1k
Default Tremec tko 600 where from ???
Anyone
Old May 29, 2013 | 08:36 PM
Mark Shead's Avatar
Mark Shead
Originally Posted by Alg1k
Anyone
If you want a UK company Real Steel Uxbridge used to keep the but check on gear ratio if they still sell them if not I am sure Reyland should sell them,
If not Google will know.
Mark
Old May 29, 2013 | 08:39 PM
Alg1k's Avatar
Alg1k
Cheers Mark,
Just found out Martins back from holiday tommorow ,
Old May 29, 2013 | 09:20 PM
LHD220Turbo's Avatar
LHD220Turbo
import one from the states, alot cheaper when i was looking
Old May 29, 2013 | 09:27 PM
JamesH's Avatar
JamesH
There was one for sale on here a couple of weeks ago
Old May 29, 2013 | 09:33 PM
Jay,'s Avatar
Jay,
Sponsor
http://www.roadcraftuk.co.uk/index.p...product_id=620
Old May 29, 2013 | 10:31 PM
Alg1k's Avatar
Alg1k
CHEERS Jay
Im going on a trip tommorow
Old May 30, 2013 | 06:19 AM
Jay,'s Avatar
Jay,
Sponsor
who does the bell housing adapters
Old May 30, 2013 | 07:17 AM
MK MOTORSPORT's Avatar
MK MOTORSPORT
hi jay
you just adapt t5 bell housing quite easy to do
mark
Old May 30, 2013 | 08:18 AM
Mk2_2dr_2L_Escy's Avatar
Mk2_2dr_2L_Escy
Sorry to jump in, but I am also considering going to a tko box and I notice that the input shaft tip is of greater diameter than the T5 box, what solutions have guys come up with for this? Or are we stuck modifying the crank or input shaft of the box?
Cheers,
Damion
Old May 30, 2013 | 08:22 AM
Martin-Hadland's Avatar
Martin-Hadland
1st to 200 without NOS
Cheers,
Damion
You can buy a different spigot bearing that does the job.
Old May 30, 2013 | 08:23 AM
Alg1k's Avatar
Alg1k
CHEERS Jay
Non in stock at the moment :-(
Old May 30, 2013 | 09:08 AM
Jay,'s Avatar
Jay,
Sponsor
So what about the jag box conversion that Euan did a few years back ?
Old May 30, 2013 | 09:26 AM
rog's Avatar
rog
Shocked at how cheap that is Bloody gaywheeldrives....get raped bigtime for decent parts and you rwd boys have it made!
Old May 30, 2013 | 09:29 AM
Jay,'s Avatar
Jay,
Sponsor
Bad isnt it Rog were proper raped we are
Old May 30, 2013 | 04:25 PM
Cosnada's Avatar
Cosnada
What are you going to do about a clutch and propshaft?
Old May 30, 2013 | 04:52 PM
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
You will need to fit a Pro5 shifter to the TKO to make it a similar change to the T5. It really is a bomb proof box been in mine for 13 years now.
Old May 30, 2013 | 04:56 PM
Staffi's Avatar
Staffi
Rod,
What Diff do you run on yours??
Sorry to slightly go off topic Daz
Old May 30, 2013 | 05:03 PM
Moonstone Steve.'s Avatar
Moonstone Steve.
Rod uses the Jag diff IIRC Pete.
Steve
Old May 30, 2013 | 05:09 PM
Staffi's Avatar
Staffi
Ok, thanks Steve.......
Old May 30, 2013 | 05:35 PM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
13 years lol I can remember you busting your t5 racing Matty whitland in his yb mk1 escort! Time go's fast!
Old May 30, 2013 | 07:50 PM
turnover's Avatar
turnover
Got a nice tremec t56 sat here doing nothing
Old May 30, 2013 | 07:54 PM
Alg1k's Avatar
Alg1k
I have 7,1/4 tripple clutch allready
and my mate owns Dave mack propshafts
His names Dave LOL
Hes just done some carbon props for another friend Nigel who owns the monster
truck big foot, or one of them i should say,
So i may be having a carbon prop,,
Old May 30, 2013 | 07:55 PM
Alg1k's Avatar
Alg1k
Cheers Rod ,
Its on the list.
Old May 30, 2013 | 08:00 PM
Staffi's Avatar
Staffi
Is this for the Dolly Daz?
Old May 30, 2013 | 08:03 PM
Alg1k's Avatar
Alg1k
Yes mate the new one not the cobbled together red one.
Old May 30, 2013 | 08:07 PM
Alg1k's Avatar
Alg1k
nice 6th gear for cruising
.50 and some .62
Could be an option .
Is it new ??
Old May 30, 2013 | 08:11 PM
Mark Shead's Avatar
Mark Shead
.50 and some .62
Is it new ??
When I had a .63 5th in my Tremec you couldnt use 5th under about 100mph so it was useless.
Mark
Old May 30, 2013 | 08:13 PM
Alg1k's Avatar
Alg1k
Mark
LOL
May be ok for me as im running 13" wheels most of the time
Old May 30, 2013 | 08:20 PM
Mark Shead's Avatar
Mark Shead
LOL
Didnt think of that, It would be worth working out the rpm per 1000rpm and see what it is,
For me the tremec on stock final drive and .82 or .83 what ever it is was just about right for a Cossie.
Also look at the speedo drive as one is electric and the other is cable from mem.
Mark
Old May 30, 2013 | 08:43 PM
mark r's Avatar
mark r
fuck that's cheap!!!
Old May 30, 2013 | 08:48 PM
Alg1k's Avatar
Alg1k
[QUOTE=Mark Shead;6258037]Didnt think of that, It would be worth working out the rpm per 1000rpm and see what it is,
Mark[/QUOTE
23 mph per 1k
About 180 ish
I've got a didgital speedo that runs of the front wheel
So that will save ME, at least the bother of cables.
Good call though for other people wishing to convert to the tko,
Old May 30, 2013 | 09:01 PM
neilnewboy's Avatar
neilnewboy
Just seen this??
http://www.rodsnsods.co.uk/forum/stu...ng-parts-82129
Old May 30, 2013 | 09:27 PM
stevieturbo's Avatar
stevieturbo
C**t
Mark
23 mph per 1k
About 180 ish
If you're considering the T56, the drop from 4-5 and 5-6 is huge unless you get one with the 0.83/0.63 5th and 6th. ( there are a few variations, but they're mostly around there. )
The tall 0.74 and 0.5 5th and 6th are huge and make almost any gearing setup awkward.
It works ok on a big V8 with lots of torque though.
Short diff and short overall gearing may help this, but I'm sure it still wont be ideal
Most boxes can run either cable or electric speedo sender, although the T56 is normally electric, so to convert for cable will cost.
I'd guess the TKO could be ordered with either.
The newer TR6060 is regarded as a much better box than the T56, although again comes in a variety of ratios and fitments.
Old May 31, 2013 | 12:00 AM
turnover's Avatar
turnover
I presume your running high hp for the reason for a tko ?
Old May 31, 2013 | 02:21 PM
scoooby slayer's Avatar
scoooby slayer
http://www.summitracing.com/parts/cm...make/chevrolet
Old May 31, 2013 | 02:27 PM
stevieturbo
C**t
As with any big purchase, no way would I be buying a transmission from the US from a catalogue.
You must speak to a human being and discuss what you need.
RPM Transmissions is a popular choice, or Tick Performance ( at least around GM stuff )
Old May 31, 2013 | 05:09 PM
turnover's Avatar
turnover
What you running in yours Stevie 6060 ?
Old May 31, 2013 | 05:13 PM
stevieturbo
C**t
Just an old T56.
It is a rebuilt unit and is supposed to have better shift forks, baulk rings and does have a Viper 31 spline mainshaft and supposed to have cryo'd gears.
That said, the original T56 totally standard T56 I had before never gave me any trouble at all, and still have it as a spare.
I wouldnt say I'm overly abusive when it comes to gearboxes though.
From reports on the 6060, one would be nice, but that's a US$5k nice, so wont be happening any time soon lol
Old May 31, 2013 | 08:20 PM
turnover's Avatar
turnover
Just an old T56.
Yeah they do take some abuse the one I have is from a viper with the larger output shaft ,just need something to bolt it to Chevy twin tub would be nice ,but just can't make my mind up
