L8 ECU+ Collins Pro monitor+ Magnecor leads+ billet crank pulley
Hello,
I will be selling my green sticker L8 ECU with a Collins chipset and baby board already installed in it. The chip is for use with a T34.63 with greys and RS500 I/C. This particular setup is the best by far I have tested so far (including many others famous tuners chipsets and boards) and has worked flawlessly on my car for about 2 years. Only selling because I am upgrading to an Autronic SM4.
Photos of the ECU and Collins chipset - baby board. SOLD.
I will also sell my Collins monitor (professional version), in perfect working condition too. Displays a variety of data collected from the engine's sensors, like water and charge air temp, RPM, boost pressure etc. plus fault detection. This one which is the pro version has the ability to change live the ignition timing and fuel injection. Comes with full instructions. SOLD
If someone is interested in buying both the ECU (with the Collins baby board) and the Collins monitor, I will do a special price ofc
Also, I will sell a full set of magnecor KV85 leads (all 4 plus the one coming from the coil) in perfect working condition, in need maybe of a cleaning. 70 pounds posted.
CDF racing brand new lightweight crank pulley with both 4 lung and 36-1 tooth disks. 90 pounds posted
Another L8 ECU never opened, in brand new condition, working perfectly tested on my car (stickers and CO plug untouched, perfect for a concours car maybe?). SOLD
Bailey header tank for 4wd and swirl pot (plus the hoses shown in pictures if interested). SOLD
Radtech custom made to order Turbo cooler that mounts on the slam panel (on top of the radiator and requires a RS500 I/C), in perfect condition. SOLD
Graham Goode Racing BOV, in perfect working condition. The diaphragm is intact. 70 pounds posted.
If you are interested plz pm me or e-mail me at cossie_topaloglou@yahoo.gr. Paypal payments accepted (my paypal address is the same as my e-mail).
Last edited by cossie_topaloglou; Jul 9, 2013 at 10:42 AM. Reason: New reduced prices
I like the monitor( the professional version that also temp. adjusts the sites), just wanted to ask if it'd work on a Weber L8 ecu fitted with a Pectel board or is the monitor programmed to the superchips add-on board photoed inside th L8 ecu?
Let me know, Thanks.
PRO-LINE MOTORSPORT
Sep 28, 2015 09:54 PM
