Power steering cooler
Old May 27, 2013 | 08:03 PM
jonfoc's Avatar
jonfoc
Default Power steering cooler
Should the rad be fitted pre or post rack?
Jon
Old May 27, 2013 | 10:15 PM
stevieturbo's Avatar
stevieturbo
C**t
Cooler should always go on the low pressure side.
Unless you've found a cooler than can withstand over 1000psi
Old May 27, 2013 | 10:40 PM
Sonic Boom's Avatar
Sonic Boom
As above it should be fitted on the return to the tank, to be fair you'd struggle to fit it any other way.
Rich
gcfcos
59
Oct 6, 2015 05:04 PM
