I would think it would be a good thing , not sure about it at high speeds mind you , I think in the burton book tells you the turns there quick racks do think its around 2.1 turns
power steering rack ie cosworth one , pump, tank, crank pulley and belt to drive the pump or if your not wanting to lose the bhps you could go for a pug electric set up ?
