clutch help please
Old May 27, 2013 | 01:23 PM
Dicko&Vacant's Avatar
Dicko&Vacant
Default clutch help please
Ive just had a new clutch fitted my ibiza 20vt track car as it was slipping after being mapped.
Ive gone from duel mass flywheel etc to solid flywheel and 6 paddle clutch, now my problem is the biting point is now ridiculously low as in on the floor? Soon as you start to life the pedal it wants to go, same as changing gear etc. Now I'm supposed to be on track in 2 weeks at croft rsoc so does anyone have an idea what could be wrong or will it get better with miles or maybe try bleeding it????
Old May 27, 2013 | 01:25 PM
Does the pedal get better the more you press it?
Old May 27, 2013 | 02:58 PM
Dicko&Vacant
No Glenn
Old May 27, 2013 | 09:38 PM
The Youth.'s Avatar
The Youth.
whats it like when you push the pedal down to change gear do you have to take it to the floor to disengage the clutch?
steve
Old May 27, 2013 | 09:51 PM
Dicko&Vacant
Yeah steve to the very bottom ;( will be a nightmare for Sarah to drive with her only short lol
Old May 27, 2013 | 10:04 PM
The Youth.'s Avatar
The Youth.
the cover is too close to the plate then or the release bearing too close to the cover
you could machine a bit off the cover to gain clearence thats what AP did to an RST one of mine years ago as I had the same problem but I never actually refitted it to try before selling the car
steve
Old May 27, 2013 | 11:40 PM
IanC's Avatar
IanC
Did you change the master and slave cylinder too? I had the same problem on an octavia when I changed from dual mass to single changed the cylinders and it solved it
Old May 28, 2013 | 08:11 AM
Dicko&Vacant
Im going to change the slave cylinder see if that helps
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
