Any one free to give me a bit of advice
Old May 26, 2013 | 07:06 PM
kyleb's Avatar
kyleb
Default Any one free to give me a bit of advice
I have a mk6 transit and on a morning it's getting a bit lazy to start and the heater plug light goes off pretty fast and don't know if they have heater plugs seperate or they are built in with the injectors I'm unsure any advice
Old May 26, 2013 | 07:22 PM
naturally aspirated's Avatar
naturally aspirated
When you say lazy, you mean "flattish battery" type lazy?
Old May 26, 2013 | 07:24 PM
kyleb's Avatar
kyleb
No mate turning over quite a few time more than it used to to start
Old May 26, 2013 | 07:28 PM
naturally aspirated
Even though the heater plug indicator on the dash lights up. it doesn't mean the plug is actually working. Check that first, even in this warmer weather.
Old May 26, 2013 | 07:30 PM
kyleb's Avatar
kyleb
How do you check take em out and put the ignition on and do you know where about they are located thanks for you Help aswell pal
Old May 26, 2013 | 07:53 PM
saph4be's Avatar
saph4be
Heater plugs don't matter on theses unless mega cold! Common problem is timing chain guide wearing causing timing to go out, and poor starting
Old May 26, 2013 | 09:38 PM
stu170's Avatar
stu170
Easy start. A transits best friend
Old May 26, 2013 | 09:46 PM
m11rcm's Avatar
m11rcm
Doubt it will be heater plugs on a transit especially this time of yr on a transit sounds more like timing or valve clearance or injector/ pump any fault codes ?
Marc
Rob_DOHC
Computers, Consoles and I.T.
Aug 15, 2015 11:17 AM
