Trumpets in an inlet manifold
Old Mar 16, 2005 | 06:33 PM
Charlie Chalk's Avatar
Charlie Chalk
Unknown.
Default Trumpets in an inlet manifold
what are they for, and do they have to be a certain size?
Old Mar 16, 2005 | 06:36 PM
Ryan's Avatar
Ryan
venturi effect and to cause a vaccum i think, also i would presume it seriously improves the way the air is drawn down the flutes
Old Mar 16, 2005 | 06:38 PM
GARETH T's Avatar
GARETH T
they are there to try and send the inlet pulses(which travel up the inlet track) back towards the inlet itself!
size and shape matters,,, alot
Charlie Chalk
Unknown.
doesnt matter what size then so long as thee all the same and the inlet is tapered?
Old Mar 16, 2005 | 06:40 PM
Charlie Chalk
Unknown.
oh didnt see that
Old Mar 16, 2005 | 07:22 PM
RWD_cossie_wil's Avatar
RWD_cossie_wil
the bell mouth actually increases the velocity of the air , and smooths the airflow out, the ratio of bellmouth diameter to lenth will dictate your engine charicteristics, ie long narrow bellmouths will generally give better low down response while wide shortones will give better top end power
Old Mar 16, 2005 | 08:27 PM
Keith B's Avatar
Keith B
to elaborate on RWD Cossie wil's answer: The shape allows a higher reynolds number (related to flow coeff) different lengths and radii can be used to tune the flow for different rpm. As will says long for low down and short for top end.
Nov 1, 2015 06:53 PM
Fudgey
21
Sep 30, 2015 06:19 PM
Johnny Knoxville
Sep 30, 2015 07:21 AM
caprixpack
Sep 25, 2015 07:53 PM
