Mondeo ST TDCi Crankshaft Pulley
Old May 18, 2013 | 06:54 AM
Brian's Avatar
Brian
Default Mondeo ST TDCi Crankshaft Pulley
Our Mondeo ST TDCi has started to develop a rattle from the engine, I believe its the crankshaft pulley, I have read on line its best to use genuine ford parts
Is there a cheaper place to get the kit from than Ford Parts UK?
http://www.fordpartsuk.com/shop/ford...ISC4_c_456.htm
Brian
Old May 18, 2013 | 08:07 AM
Mark RS's Avatar
Mark RS
Brian
Pm daviddunlop83 he has done a few on his st. I think he found a cheaper one but I'm near sure it didn't last. Prob better getting genuine ford.
Old May 18, 2013 | 08:25 AM
RichieST's Avatar
RichieST
Send a message to graham on car parts express website, normally comes up pretty cheap for genuine bits, I get quite a few parts from him!
Old May 18, 2013 | 08:52 AM
Brian's Avatar
Brian
Do you have a link to his website? I just Google car parts express but couldn't find it
Brian
Old May 18, 2013 | 08:53 AM
Brian's Avatar
Brian
I have a heard to only use genuine Ford parts
Brian
Old May 18, 2013 | 08:59 AM
RichieST's Avatar
RichieST
Brian
http://www.carpartsexpress.co.uk/
This is the website, can't get on it though, not too sure what's up there!
Old May 18, 2013 | 09:04 AM
Brian's Avatar
Brian
Yeah that's the one i tried Do you know his email address? does he post on here?
Brian
Old May 18, 2013 | 09:28 AM
Csm's Avatar
Csm
I bought one from transit parts .......... dont fucking bother, fitted it and it sounded ten times worse than the noisey original and it was throwing the belt around that it wasnt going to stay on so those are best avoided.
My original was put back on and still is on although still want to get it changed, ford parts do a kit with a tensioner aswell but its between 300-400 quid be near 400 if you buy the 2 seperate rollers aswell.
exspensive
Old May 18, 2013 | 10:49 AM
RichieST's Avatar
RichieST
Brian
Just tried his website again and it now works! Send a parts enquiry through his website.
Old May 18, 2013 | 12:12 PM
Brian's Avatar
Brian
exspensive
Sounds like I definitely need to get genuine ford bits then!
Brian
Old May 18, 2013 | 12:13 PM
Brian's Avatar
Brian
Cheer's Rich just sent a enquiry
Brian
Old May 18, 2013 | 02:15 PM
daviddunlop83's Avatar
daviddunlop83
I fitted gates pulley kit with genuine ford crankshaft pulley.
I did fit a febi bilstein one before and it failed within a month, tried a other one which also failed so went for genuine which isn't that much more.
Best to get the gates kit for tensioner etc as its cheaper
Here is link to gates kit tho may be cheaper from your local motor factors
http://www.roadrunnerautoparts.co.uk...tail.aspx?id=1
Just noticed gates do a crank shaft pulley which might be worth trying as its half price of the ford one
http://www.roadrunnerautoparts.co.uk....aspx?id=17263
Old May 18, 2013 | 02:24 PM
Brian's Avatar
Brian
Thanks mate will have a look
Brian
Old May 18, 2013 | 02:39 PM
Csm's Avatar
Csm
Excellent link Davie dunlop
Old May 18, 2013 | 02:40 PM
Brian's Avatar
Brian
Been reading and apparently the Jaguar kit will fit
http://item.mobileweb.ebay.co.uk/vie...id=61545617280
Anyone know if this is the case?
Old May 18, 2013 | 02:45 PM
Csm's Avatar
Csm
Fuckin good shout Brian
When my electronic actuator fucked up the one i bought came from a jag x type i just matched the part numbers
Old May 18, 2013 | 04:06 PM
DangerousBryan's Avatar
DangerousBryan
The ford kit is a tsb to stop pulley/belt rumble. You get crank pulley,tensioner and belt. That engines a noisey twat though what ever you do.
Old May 19, 2013 | 04:37 PM
DanW@FastFord's Avatar
DanW@FastFord
Spelling Club King!
It's best to do the pulley and tensioner at the same time. Getting the cheapest one is a false economy, as you'll be replacing it again not long after!
Old May 19, 2013 | 08:02 PM
Brian's Avatar
Brian
Does anyone know if one from Jaguar will fit? or just go with the Ford one?
Brian
Old May 26, 2013 | 02:30 PM
Csm's Avatar
Csm
Did you ever find out about the jag kit ?
Dont see why it would be different though as everything is stamped ford under the jags bonnet as all the seem to have done is put jaguar on the plastic engine cover.
Old May 31, 2013 | 10:54 PM
Brian's Avatar
Brian
No mate I never I just ordered the kit from Matt Lewis Motorsport, fitting it tomorrow
Brian
Old Jun 1, 2013 | 08:14 AM
Csm's Avatar
Csm
Ok matey, does he list these i will take a looky
Old Sep 17, 2014 | 09:10 PM
RB2004's Avatar
RB2004
Old Topic... but just a heads up, purchased an SKF tensioner kit, with ALL rollers and tensioner for just over £120, and its the same as the ford parts, on the reverse where the ford logo and part numbers were on the original, it had been ground off.
Same with the SKF tensioner which is for the power steering pump / water pump.
So if you want Genuine ford parts for 1/2 the price, just need to purchase the SKF belt tensioner kit / tensioner and its identical... irony is its more complete as well as it has the 2 other rollers in the box which ford sell separately.
Tensioners are actually made by Liten, but SKF are boxing them up as part of their own kits.
Old Sep 18, 2014 | 04:32 AM
How can a company buy ford parts then sell them off as there own but cheaper lol.
Good tip matey
Old Sep 18, 2014 | 07:12 AM
RB2004's Avatar
RB2004
Seen it several times,
In this case liten make the tensioners for ford, they also sell same part as a pattern part... But aren't allowed to sell it with the ford logo.... So they grind it off, then SkF buy it and stick it in their kit.
Happens often, last year I fitted a thermostat housing on a bmw 3 series, it was identical to genuine part and bmw logo had been ground off it.
So whenever you see a part with logo ground off it usually indicates its same as dealer is selling just wirhout the logo.
Old Sep 18, 2014 | 01:03 PM
A.J.'s Avatar
A.J.
Jag x type pulley and tensioner kit does fit, got it on mine, pulley is uprated version as well !
Old Sep 18, 2014 | 02:10 PM
AJC's Avatar
AJC
I have fit a Unipart one to mine, been good as gold for 8000 mile so far, it was about £40 as opposed to £150ish for the Ford one.
I read somewhere about fitting an x type jag one
Old Sep 20, 2014 | 07:51 PM
A.J.'s Avatar
A.J.
ford tsb recommend changing tensioner if changing pulley due to rattling, complete jag kit is only about £20 more than pulley from ford, no brainer for me, pulley, tensioner, new bolts, belt and a new guard £179....... ford pulley £160 !!
Old Sep 20, 2014 | 07:55 PM
botters's Avatar
botters
competant bodger
i gives me a great amount of pleasure when i get customers jags in work and tell them that it has the same engine as a transit van lol
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
wowk
Mar 30, 2021 07:49 PM
Nov 1, 2015 06:53 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
The Enigma
Sep 29, 2015 10:31 AM
