2007 Mondeo TDCI heavy smoke
Old May 16, 2013 | 02:31 PM
riz325's Avatar
riz325
Default 2007 Mondeo TDCI heavy smoke
hi all
my car is smoking heavily the smoke is pure black when setting off and only last between 1500rpm to 2500 rpm then gets a bit better also when iam going uphill will smoke so much that i cant see behind when i put foot on gas sometimes needs a bit of power just to move the car from standstill i have searched the forum and no one has the same problem
checked all pipes and they are perfect no rips build up good pressure they have been taken off the car one by one
also have changed the intercooler just in case that was the problem but still the same
car has been decated just to see if it makes a differnce but nothing still the same
changed the electric acutator for the turbo aswell just incase it sticks open
turbo spools over no play on the shaft
egr and inlet been cleaned out plus egr has been blanked off using a blank with a hole in it for the euro 4 model
i have noticed a noise from the air box kind of rumble that gets louder i ve checked all hoses from here and have had it of the car to check for splits but nothing
car has recently had new injectors fitted and new clutch flywheel
car is a taxi and has done 160k
any advice would be much appreciated cant drive the car as its to smokey and dangerous for ppl behind me
cheers
mark94
Oct 10, 2023 06:52 PM
wowk
Mar 30, 2021 07:49 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
Steve Escos
Oct 1, 2015 06:57 AM
The Enigma
Sep 29, 2015 10:31 AM
