afr limits for mfi
Old May 12, 2013 | 04:43 PM
stwibs's Avatar
stwibs
Default afr limits for mfi
Having installed an AEM failsafe afr gauge I'm after a bit of input into what sort of value I should set the alarm levels to when on boost.
I have the gauge currently set up to alarm when on boost if the fuelling isn't between 11 and 13.
Does this sound about right ?
thanks
Old May 12, 2013 | 09:53 PM
AstoN_B's Avatar
AstoN_B
An eye for detail...
im no expert but those figures don't sound too bad.
I'd be interested to get a solid figure too as i'm getting a wideband monitor shortly for mine.
Where'd you get yours and how much?
Old May 13, 2013 | 03:42 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Depends on boost, 13.0:1 at 7psi is just about ok but at 30psi you'd have a dead engine! lol
Old May 13, 2013 | 06:44 PM
project rs's Avatar
project rs
i would of thought when cruising you'd see afr's higher than 13
Old May 13, 2013 | 07:05 PM
stwibs's Avatar
stwibs
It was off ebay from a shop in US, from memory bout Ł180 all in.you can configure the centre and outer displays to be either boost or AFR then set limits to operate a relay.
Karlos, its holding 16psi,what do you think would be a good value to set it to alarm at with that boost level ?
its more the on boost levels I'm after as I am using the afr gauge alarm output to cut the boost.
cheers for all the input
Old May 13, 2013 | 09:51 PM
Karlos G's Avatar
Karlos G
Balls Deep!
I would set it to come on over 12.0:1 at 16psi.
Chas
Oct 5, 2015 07:13 PM
SMILER258
Sep 28, 2015 09:04 AM
wheelwizardrefurbs
Sep 22, 2015 05:45 PM
stevierob
Sep 7, 2015 07:09 PM
