Drilled Numberplate Pic Request
Ages ago i saw a red mk4 escort sleeper, rs turbo engine fitted. It had a drilled front number plate, 2-3mm holes in 50mm circles across it to aid airflow.
Anyone remember this?
Pics?
Pics?
Legal - Ermm dunno.
Not overheating probs, just the numberplate blocks alot of the airflow to the ic n rad I had an extended "rip session" at the weekend, 4-5mins of hard driving n the coolant reached mid 90s and the inlet temps were high 30s.
The gaps in the Orion bumper face directly at the end tanks of the IC, id like to mod the bumper somewhat, but the plate would still block alot of airflow. Just wanna improve it!
what intercooler you got rog? I had a similar problem with getting hot quicky. and now just wack the heaters on. my bumper also blocks a fair bit of the rad/cooler as its a poverty spec bonus.
I genuinely believe the small holes in the plate will make no difference, I was reading up on satellites when I was specking my system and the general info I was given was over certain windspeeds it made no difference, I know a satellite and car are diff but the same principals apply.
