Oil filter for the CVH....is it worth using a zetec one??!?!
Old Mar 16, 2005 | 07:27 AM
keithG666's Avatar
keithG666
Default Oil filter for the CVH....is it worth using a zetec one??!?!
Was round Dans the other week and his oil filter was a Zetec one...same dia, etc but about twice as long!!!
Is it worth getting one for mine, as i got to get one this afternoon!!!
If it is...what engine size zetec is it?!?!? and will it deffo screw on?!?!?
(as we didn't get that far at Dan's house....max couldn't undo the oil filter .....thanks Steve@SCC for doing it up soo tight!! )
Old Mar 16, 2005 | 08:17 AM
keithG666's Avatar
keithG666
YO...ANYONE?!?!?!?!?!
got to get this this afternoon!!!!
Old Mar 16, 2005 | 08:42 AM
Paul's Avatar
Paul
I thought it would hit the steering rack at the back if it was any longer
Old Mar 16, 2005 | 08:43 AM
keithG666's Avatar
keithG666
thats what i thought!!!
Old Mar 16, 2005 | 08:45 AM
Rab's Avatar
Rab
Fucking superstar........
I normally just use the stantard Motorcraft one with a jubilee clip around it.....
Old Mar 16, 2005 | 08:53 AM
Paul's Avatar
Paul
The Zetec one is a EFL600, they gave me this last time i went to fords and it did look rather too tall and would have beeni tight fit to get it on in the first place. So I got them to change it to the EFL500
Old Mar 16, 2005 | 08:55 AM
DanS's Avatar
DanS
nah theres loads of room
Old Mar 16, 2005 | 09:29 AM
Nik_W's Avatar
Nik_W
IIRC, it won't fit if you have ABS.
Old Mar 16, 2005 | 09:37 AM
COSWORTHFORDS's Avatar
COSWORTHFORDS
It will screw on as long as there is room the threads are the same.....
Old Mar 16, 2005 | 09:47 AM
keithG666's Avatar
keithG666
is it worth it though??
and which zetec model is it for??
Old Mar 16, 2005 | 09:56 AM
Ginge !'s Avatar
Ginge !
just finding my feet
whats the point
ya change ya oil every 3000 miles, they dont get that blocked, the cvh's are usually changed at 80k and dont get blocked
Old Mar 16, 2005 | 10:45 AM
SteveB's Avatar
SteveB
The S1 uses a EFL90 not a EFL500 as std....... (EFL90 is a 4x4 Cossie filter as well)
The EFL600 is used for all the zetec range and also the Focus RS
Any of the 3 will be ok....
Old Mar 16, 2005 | 11:00 AM
mattbibs's Avatar
mattbibs
they only cheap - get one and let us know if it works!
Old Mar 16, 2005 | 11:01 AM
James's Avatar
James
Why does the S1 use a different oil filter from a S2?
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
Rizlablue
Sep 6, 2015 10:54 AM
Rizlablue
Sep 6, 2015 09:58 AM
gavt123
Sep 5, 2015 10:03 AM
hopper350
Sep 4, 2015 12:53 AM
