Range rover offroader
Ranger Rover Off road truck,
This is my off roading range rover selling due to lack of time to use and to many other projects.
Its a 3.5 v8 efi auto that's been cut down and a home made fully welded cage/frame fitted this is tied into the chassis and is super strong, home made 100x100mm box winch bumper and 6mm skid plate again tied back to the chassis, petrol tank and battery relocated to rear tray, electric fan in cab switch.
265x75x16 insa special track tyres (loads of tread) and good quality modular wheels , terra firma +2'' shocks and springs with dislocation cones, winch max 17,000lbs winch with dynemma rope (not fitted in photos) wireless remote and in cab battery switch, super strong front and rear recovery points with dynemma rope bridles, bucket seats and harnesses, loads of strops shackles etc, welded rear diff, ecu and coil moved into cab.
All in all a good strong offroader the v8 is very strong and pulls really well and with the cage means you can through it at most things and not worry if it falls over, there isn't much that's stopped it and has shown up a few trucks with a lot more money spent on them.
There are a couple of little jobs that could do with looking at the wiring needs tidying up 90% of it is disconnected and can be pulled out never bothered me so just left it and the windscreen wiper needs looking at.
Its located in Lowestoft and can be viewed evenings and local delivery can be arranged at a agreed cost.
£1250 but open to offers
rsguy
44
Sep 29, 2015 03:29 PM
