Escort Cosworth WRC LHD Breaking Pictures Uploaded
Escort Cosworth WRC LHD Breaking.
Just been fully painted inside and out, underneath and under the bonnet. In Excellent condition ready to be re kitted out and used.
Parts for sale as follows -
WRC ENGINE COMPLETE WIRING LOOM TURBO EGR ETC, JUST BEEN FULLY REBUILT BY PIERO EX MOUNTUNE WRC ENGINE BUILDER, REBUILT X-TRAC GEARBOX COMPLETE 140010, 8.5" ACTIVE FRONT DIFF FULLY REBUILT, 9” VISCOUS 4.4 REAR DIFF REBUILT, 1 FULLY REBUILT MPC PUMP, 1 CARBON CLUTCH, 2REAR WATER INJECTION TANKS, 2 FLOW JET PUMPS, CARBON FUEL TANK AND 1 FUEL PUMP, CARBON FIRE EXTINGUISHER SYSTEM AND MOUNT, CARBON SPARE WHEEL TRAY, ALLOY SPARE WHEEL MOUNT, HYDRAULIC HANDBRAKE ASSEMBLY, INTERNAL FUEL LINES, GPA STEERING COLUMN, DASH MOUNT, BULKHEAD SEAL AND LOWER COLUMN , STEERING WHEEL, MAGNESIUM PEDAL BOX, HEATER ASSEMBLY, ROOF VENT, NAVIGATORS FOOT REST AND ECU MOUNT, DRIVERS FOOT REST, NAVIGATORS CARBON DOCUMENT BOX, 2 RECARO SEATS AND FORD MOUNTS, DA36 DIGITAL DASH ASSEMBLY
LHD NAVIGATORS FOOT REST AND WATER INJECTION TANK, LHD DASH UNIT, FRONT SCUTTLE, 1 PAIR CARBON DOOR CARDS WITH CORALBA TRIP, ACTIVE FRONT AND CENTER DIFF VALVE BLOCKS COMPLETE, ACCUMULATOR VALVE BLOCK COMPLETE, 2 VALVE BLOCK MOUNTS, 1 INLINE FILTER, MPC TANK WITH FILTERS, FRONT DIFF OIL COOLER, WRC REAR CRADLE COMPLETE, 4 REIGER TARMAC DAMPERS, 2 SETS OF WRC TOP MOUNTS, REAR BREMBO 4 POT CALIPERS, GEARBOX MOUNT, 1 PAIR OF TARMAC FRONT UPRIGHTS, 1 PAIR TARMAC STEERING ARMS, 6 POINT FRONT CROSS MEMBER, LHD WRC STEERING RACK WITH DRUM STICKS, 1 PAIR NEW BREMBO 8 POT CALIPERS, CARBON FLOOR TRAY WITH WHEEL BRACE
1 PAIR NEW GOLD TCAS, 1 PAIR COMPRESSION STRUTS, 1 PAIR COMPRESSION STRUT BRACKETS, 4 ARB BLADES, 2 ANTI ROLL BARS, 4 ARB MOUNTS, 1 PAIR ENGINE MOUNTS
1 WRC EXHAUST SYSTEM, 2 NEW WRC INTERCOOLER PIPES, 1 WRC CONE FILTER WITH GUARD
1 LAMINOVA, ASSOCIATED WATER PIPES AND CLAMPS, 1 PAIR REAR DRIVE SHAFTS, WRC INTER COOLER, WRC RADIATOR AND FANS, 3 BRAKE MASTER CYLINDERS WITH RESOVOIRS
All Parts Available.
can you give me a price on the above in red , do these come with the upper and lower universal joints
jessie_rs
11
Jun 3, 2019 04:57 PM
