Turbo gasket
Hi guys I have just got a S2 turbo it runs great bit it is blowing on the elbow is there meant to be a gasket between the elbow and turbo?
Also it peaks at 22psi but drops straight away to 10 do you think that could be due to the blow or just a weak actuator?
the fact that it reaches 22 psi then drops points to a weak actuator. are you still on the amal valve? could be related to a faulty amal aswell. id avoid gaskets at the turbo at all costs. the turbo flange to the header gaskets you can buy are a waste of money. i put one one when i fitted a new turbo and it blew it out the first time i put my foot down. x2 flats surfaces beat a gasket.
Ok I will have a good luck 2moro only been home a hour and half drove it home 200 miles 3.5 hours didn't miss a beat just doesn't hold boost and it's soo slow but I am used to my 3 door as a daily lol
A std t3 I believe mate
I hav had it machined flat as about a inch of it was was out buy half the thickness of a finger nail it sounds loads better now but still peaks 22 and drops to 10. Shall I just turn the boost down to say 15psi
It has a big front mount on it unlimited boost chip piper can pulley piper cam an a stage 2 head allegedly meant to be 220 bhp more like 120 tho lol
I can't get it set up as I am not keeping it only just got it but was made a offer I couldn't refuse but I need to fix a few things on it 1st
I think you are asking alot from the standard turbo to flow 22psi, id think 15/16psi a much safer bet. See if you can adjust it to run less boost.
You could also have a boost leak somewhere, like a loose hose etc. Letting 22psi past it but tight enought to hold 10psi.
Id start with turning the boost down, checking the actuator or replacing it with a -31 item then a boost leak test
As above, all sound advice!
Also a well worked head increases your engines VE dropping the boost pressure at any given power level... The head flows easier, less back pressure (boost).
yeah its surprising how much difference it makes. If you're anywhere near Jano at Oddkidd he does setups at very decent prices.
Couple degrees more advance makes it feel much crisper on the throttle.
It does feel good on throttle tbh mate just loses boost something isn't holding so I will have to have a good look through it all
All the boost pipes are tight I think the intercooler is all good and not leaking I will get the act tested and see if its any good
It's your turbo as we've said mate, a stock T3 will not hold the boost you are asking with a modified and cam'd head (or even without), an EBC might force a few more PSI out but thats not how it should be done, you need a stage 2 or 3 T3 for more power.
