Rear Anti-Roll Bar on a Series One RS Turbo Question
Old Mar 15, 2005 | 06:32 PM
M7 COS's Avatar
M7 COS
Default Rear Anti-Roll Bar on a Series One RS Turbo Question
Firstly did the Series One originally come with a rear anti-roll bar?
According to last months Fast Ford the Series One has a 16 mm front anti-roll bar and a 12 mm rear anti-roll bar. It also said "No other MK 3 Escort had this rear, not even the RS1600i."
Well I can't seem to see a rear anti-roll bar on mine, it's quite possible I'm being a total idiot and not seeing what is blatantly in front of me, but some clarification would be nice!
Would there be any reason for removing the rear anti-roll bar? If you changed the suspension for instance. The front one is definitely there (I think!).
Any help or advice appreciated.
Thanks
Old Mar 15, 2005 | 06:41 PM
cpt scarlett's Avatar
cpt scarlett
hi mate yes the series 1 did have a rear roll bar it connects to the lower arms with a bushed link bar hope thus will help. some people take them off when running coil overs on the rear cheers tomy.
Old Mar 15, 2005 | 06:52 PM
It's Czech Mate's Avatar
It's Czech Mate
RS1600i has one on the parts list for the first production run before they went to the bigger 55l fuel tank but it was never fitted.....lol.
I know they can be had if you can find an Orion of the correct age tho
Old Mar 15, 2005 | 07:16 PM
NUTS RuS's Avatar
NUTS RuS
Suspension changes have no bearing on removing the rear ARB as it mounts off the pressed steel arms. Some have them and some dont. A 12mm vertically mounted bar aint gonna do much anyway. They actually drive better without it imho
Old Mar 15, 2005 | 08:18 PM
M7 COS's Avatar
M7 COS
Thanks for the replies guys.
So it's quite possible someone's removed mine in the past or that it never had one in the first place?
CheeRS
Old Mar 15, 2005 | 08:27 PM
essexrsturbo's Avatar
essexrsturbo
you proberly just cant see it as it hides behind the chassis if you look from the back.
Old Mar 15, 2005 | 08:29 PM
Lloyd's Avatar
Lloyd
escort mk4 cossy 4x4
i think i have one of these,took it off a turbo technic converted mk3.i think the rollbar fits into link bushes that are bolted to the rear trailing arms.so if yours has holes drilled in them ,its been removed.
NUTS RuS's Avatar
NUTS RuS
Check out the rear arms, if they have a bracket for one to be fitted then it would have left the factory with one fitted. If replacement arms have been sourced without the bracket then it will have been removed.
Old Mar 15, 2005 | 08:36 PM
M7 COS's Avatar
M7 COS
Originally Posted by essexrsturbo
you probably just cant see it as it hides behind the chassis if you look from the back.
Yeah you're probably right mate knowing me!
Thanks for all the replies I'll have another look tomorrow.
CheeRS
Wilsfoci
15
Mar 30, 2016 10:26 PM
A.t.p
Aug 15, 2015 11:37 AM
track.focus'd
Aug 12, 2015 05:53 PM
Bosch
Aug 4, 2015 05:14 PM
Graceland
Jul 31, 2015 10:34 AM
