1966 ford fairlane 2dr post
RARE SEDAN HAS 351 WINDSOR ALUMINUM INTAKE,HOLLEY DOUBLE PUMPER CARB,MALLORY IGNITION,LONGTUBE HEADERS,ALUM.VALVE COVERS,PULLEYS,WATER PUMP AND RAD.ELECT.FAN.C6 TRANS WITH REVERSE VALVE BADY 3500 STALL CONV.AND B&M SHIFTER.15 GAL.FUEL CELL WITH SENAING UNIT ELCT.FUEL PUMP AND FILTER,STEEL BRAIDED FUEL LINE,BATTERY IN TRUNK WITH REMOT SHUT OFF.FACTORY FRONT DISC BRAKES.REAR SUSP.HAS LADDER BARS WITH COIL OVERS,9 INCH REAR WITH LIMITED SLIP 4.10 GEARS MODULER IRON CASE.HAS OIL PRESS.WATER TEMP.VOLTMETER,FUEL PRESSURE GAUGES,ROLLBAR,STEREO AM/FM CD PLAYER.LOWER LEFT QTR. HAS RUST SPOT THE REST OF THE BODY IN GOOD SHAPE.
http://www.collectorcarnation.com/Ot...html?aid=32801
