HO Inlet, FRST inlet, 2wd cossie cooler, mk2xr2 parts & OFAB
Fiesta RS Turbo OFAB ecu. Only selling as I'm looking to use an OFAM ecu £100 no offers
MSD Custom live map. This is a custom map for a 1.9 cvh efi on OFAB management. The car was running 2wd cosworth t3, 2wd cosworth intercooler, cvh34 cam, big valve head, bosch 701 beige injectors, 2.5 bar map sensor, 7.5 : 1 compression ratio
This is a custom map, not to be confused with the mail order generic maps you can buy from MSD. They achieve better results by doing the mapping live. This cost £350 to have done and the car absolutely flew after it.
SOLD!
mk2 xr2 ARB powedercoated silver with powerflex poly bushes SOLD!
mk2 xr2 tiebars/chassis brackets with flo flex poly bushes SOLD!
mk2 xr2 lower arms with flo flex poly bushes SOLD!
Complete zetec H O inlet SOLD!
Fiesta RS Turbo inlet manifold. Does NOT come with injectors, ACT sensor, water temp sensor or wiring loom. Freshly painted and was never fitted. SOLD!
2wd Cosworth intercooler with modified end caps. Was used on my xr2 good condition £35 posted
SOLD!
No mate.
I think it would be a case of swapping somwe pins around on your loom and getting the correct map sensor (which I think I have).
Perhaps someone can confirm for sure?
I know you can use an xr2i cvh efi loom by swapping a couple pins on the loom so don't see why not>
Grant
Grant
Billy_RS
16
Oct 11, 2025 09:41 PM
FlashRS
13
Aug 31, 2015 06:02 PM
155lee
Aug 14, 2015 11:21 AM
