Mondeo Mk3 Grill.
In general, yes, but not without a spot of (easy) trimming to the grille, and in some cases enlarging the key hole. Although if you have a prefacelift ST, or Zetec S the facelift grilles will fit as the bumpers are slightly different where the grille fits
The Grill sits out a bit further on the facelift as the bumper is slightly different.
Had to hack saw off the lower silver central inside tab.........
This means the actual keyhole is more recessed i.e further back so I used a Dremel it increase the hole in the plastic surround.....as it's behind the Ford badge it's not noticeable. Also drilled two additional holes for the two screws in the top plastic just to ensure it sits in tight!
Looks good, worth the effort!
Anyone wanna buy a pre facelift grill in Panther black lol
B
B
mk3ste
Oct 17, 2021 10:09 AM
wowk
Mar 30, 2021 07:49 PM
Steve Escos
Oct 1, 2015 06:57 AM
