Ford Focus ST225 (MK2) 2005-2010 Everything relating to the Mk2 ST225 preface & facelift versions from 2005 to 2010
Focus st2 to 300bhp!
Old Apr 9, 2013 | 12:57 PM
Lesanimal's Avatar
Lesanimal
Default Focus st2 to 300bhp!
Alright folks! New here and bought a focus ST2! Looking to get it up to 300 bhp (ish). Going to get it re mapped..intercooler...cold air induction...full exhaust wi de cat! any ideas what else a could be doing to get there or am i going about this wrong in the first place?? any help would be mucho appreciated, keep it simple tho!!!!
Old Apr 9, 2013 | 07:50 PM
chris cdti's Avatar
chris cdti
Them mods listed will give about 300bhp and a load of torque. But this will ruin the standard clutch in no time so save up for a focus rs clutch as a minimum
Old Apr 10, 2013 | 08:30 AM
Rudders666's Avatar
Rudders666
ST330 :D
Yep. From standard, take a remap like DSCI from Dreamscience in Hull. Then CAIS, Intercooler, Full exhaust inc. downpipe and remap to something like Mod X. You must get an RS clutch fitted though or you'll go nowhere. With just the full exhaust and remap my standard clutch was slipping like mad. Everyone's clutch varies as to when it gives up but when you get up to this level it'll be dead via the torque alone.
Old Apr 10, 2013 | 04:45 PM
thebigmacmoomin's Avatar
thebigmacmoomin
I run Dreamscience DSCi map, k&n panel filter, Airtec gen3 intercooler, a uprgraded downpipe & sports cat & my orignal ST clutch is perfectly fine with no slip.
Old Apr 10, 2013 | 04:48 PM
russ rs's Avatar
russ rs
Mods your on about get you there de cat and sound awesome. Discs pads are must them dmf and clutch and lowering springs
Old Apr 10, 2013 | 05:29 PM
Rudders666's Avatar
Rudders666
ST330 :D
Only a matter of time moomin. Might last for a bit at around 270 but eventually you'll probably have to give in I'm afraid
Old Apr 13, 2013 | 11:23 AM
thebigmacmoomin
Hope not, been using the DSCi map for a year now. My get a new car this year anyway (want an 2004 M3 in purple)
Old Apr 13, 2013 | 12:37 PM
scottyfocus's Avatar
scottyfocus
What year is your ST? 07 plates for some reason the clutch is alot stronger so it may last for a while before it slips. Stage 1 it could last a while but once you go 300+ then its only a matter of time.
Old Apr 13, 2013 | 07:50 PM
Thrustyjust's Avatar
Thrustyjust
My 2007 clutch liked the Mountune mods, with as much grip as a pot of grease and was changed the following week. It had 29k miles on mine when changed. I know 56 plate cars running 300 bhp with 90k on the original clutch, so its a bit of a lottery.
Old Apr 16, 2013 | 07:08 PM
st3v3's Avatar
st3v3
The clutch IS just that a lottery.
Back on the pre-facelift a shed load of customers decided to moan to Ford about the heavy clutch in thier ST's,So Ford in thier wisdom, for the facelift model decided to alter the pressure by about 25% to give a lighter feel, but 25% less clamping pressure,hence show the car anything like an increase in torque the cluch craps it self and runs away.
I this week have been trying to arrange a group buy for the full RS clutch kit,inc slave,DMF,fitting,vat ect and the best price so far is Ł900 all in,the worst being Ł1284.
Not cheap this power lark!
Old Apr 16, 2013 | 07:24 PM
Rudders666's Avatar
Rudders666
ST330 :D
I have pre-face and it still gave and you are completely right it is a total lottery. I can recommend a guy that will do it cheaper by probably a good Ł100 on your quotes if you're interested? He's in Ashton-Under-Lyne
Old Apr 16, 2013 | 07:26 PM
Fordmad!'s Avatar
Fordmad!
Nevermind all that get some pics up!
Old Apr 16, 2013 | 07:31 PM
Rudders666's Avatar
Rudders666
ST330 :D
Of what? Lol
Old Apr 18, 2013 | 07:17 PM
st3v3's Avatar
st3v3
give us a clue of what we should be putting up pics of matey?
My arse maybe
Old Apr 21, 2013 | 07:56 PM
st3v3's Avatar
st3v3
Old May 10, 2013 | 10:08 PM
S111YST's Avatar
S111YST
I have about 280 bhp in mine and had 2 get the rs clutch kit fitted. Expense well worth
Old Jun 7, 2013 | 09:40 AM
streetsleeperst's Avatar
streetsleeperst
touch wood been running about 290bhp for last 3 years on DSCI map, Decat and standard cat, intercooler and DS Induction and still have standard clutch has done 30k miles with standard clutch and that power
Old Jun 7, 2013 | 11:08 AM
Rudders666's Avatar
Rudders666
ST330 :D
It's all down to luck. Every clutch is individual on slipping
wowk
Mar 30, 2021 07:49 PM
tankybaby66
Feb 6, 2016 02:24 PM
Sp3no
Sep 27, 2015 07:23 PM
Tank Mike
Sep 26, 2015 08:07 AM
