Pics of mk3/4 escorts with rs2000 engines.
Old Apr 8, 2013 | 07:28 PM
dav105e's Avatar
dav105e
Default Pics of mk3/4 escorts with rs2000 engines.
I'll start. Mine needs a few bits of bodywork still. I've put some decals on to be a bit different.
Old Apr 8, 2013 | 07:49 PM
shauns's Avatar
shauns
nobody knows me..
Liking this......how easy is this to do ?
Old Apr 8, 2013 | 08:07 PM
dav105e's Avatar
dav105e
At first wasn't easy but just had to cut the engine mount bracket off the drivers side and make a new one a bit further back. Zetec throttle cable and had to modify the pedal. Wiring for me was a nightmare but my mate came and sorted that. Will be doing a diagram of it soon just incase I need it lol.
Old Apr 8, 2013 | 08:17 PM
doga-ot's Avatar
doga-ot
I found this a piece of piss to do took engine out sorted mount and fitted rs2000 lump in an mk2 orion mk1 orion and mk4 escort, you can either use your original gearbox or use rs2000 one which is 10/20mm longer if iirc so is tight and you have to trim inner wing, you use the cvh engine mount to fit it but have to adapt it b cutting a bit off of it.
Wiring is a pain in the arse I did 2 different ways;
1st way was to use rs2000 engine loom with pats and wire into standard mk4 loom
2nd way was to use rs2000 removing the pats by using an early rs2000 ecu if you can find one they are rare or have your ecu fucked about with this way was a pain in the arse so on the following engine conversions I reverted back to my 1st way however I did have this car running this way but it was hard work and long winded
Old Apr 8, 2013 | 08:22 PM
dav105e's Avatar
dav105e
This was my first conversion I've done. Yeah I used the non pats. I spent nearly a whole weekend following diagrams on the net that had been done. My mate came round and did it in about an hour lol. I used the 1.6 gearbox. Once on the road I sheared the driveshafts after not even an hour but now have rs turbo ones and touch wood it's been fine.
Old Apr 8, 2013 | 08:29 PM
doga-ot's Avatar
doga-ot
don't rush but source a rst s2 box make sure it is rst box with lsd bud then see how much fun you have when you can get all the power down
Old Apr 8, 2013 | 08:30 PM
doga-ot's Avatar
doga-ot
I do like your mk3 especially in that colour
Old Apr 8, 2013 | 08:33 PM
dav105e's Avatar
dav105e
Cheers, are s1 and s2 the same or are mounts different?
I won't be getting a lot done as my dad is moaning that he helped me get mine
On the road so I gotta help him do his 100e lol
Old Apr 9, 2013 | 11:29 AM
Looks well.Any pics of the engine bay.
Old Apr 9, 2013 | 07:28 PM
dav105e's Avatar
dav105e
Old Apr 9, 2013 | 08:01 PM
doga-ot's Avatar
doga-ot
No bud they will both fit but the S1 has slightly different bolt pattern but still goes in piece of piss I fitted an uprated S1 box with quaif atb for S2 into it as my Rst S2 kept blowing boxes.......
1 thing though ditch that exhaust lol
Old Apr 9, 2013 | 08:31 PM
mk22door's Avatar
mk22door
Fart of the Purniture
Nice.
I like it
Old Apr 10, 2013 | 08:44 AM
dav105e's Avatar
dav105e
That back box will be going lol
Old Apr 10, 2013 | 08:54 AM
maido's Avatar
maido
my mk4... second pic was took last week after freshening the bay up a bit
Old Aug 11, 2013 | 10:46 AM
fonfe123's Avatar
fonfe123
That's my old one
http://www.ebay.co.uk/itm/2513165609...84.m1558.l2649
Used a 1.4 cvh box and never had any problems at all.
Killed an RST clutch on it though!
Old Aug 11, 2013 | 08:48 PM
gjh's Avatar
gjh
Look nice those 2 do.
Vincereese
Jun 1, 2023 09:14 AM
Pwrs2k
120
Oct 16, 2015 03:16 PM
FlashRS
Sep 14, 2015 12:36 PM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
