How do you change the front diff oil - help !
Old Apr 5, 2013 | 07:19 PM
Molinites's Avatar
Molinites
10 Year Member
Default How do you change the front diff oil - help !
Hi, anybody know how you change the front diff oil and if you need a new gasket or sealant ? Had a look with it jacked up but couldn't see an obvious drain plug ?
Thanks
Old Apr 6, 2013 | 09:50 PM
YBT200's Avatar
YBT200
You don't have a drain plug, loosen all the lower cover bolts , remove it, clean it , seal it , tighten it and fill from the filling plug that you have on the side. Hope this helps you !!
Old Apr 7, 2013 | 08:50 AM
Molinites's Avatar
Molinites
10 Year Member
Thanks, just thought it was weird not having a drain plug ! Thanks.
Chas
Sep 21, 2015 08:57 PM
C2 MAK
Aug 20, 2015 09:46 PM
ekjim
Aug 17, 2015 08:57 PM
st220kyle
16
Aug 14, 2015 06:13 AM
track.focus'd
Aug 12, 2015 05:53 PM
