S2 RS Turbo parts - loom, gearbox, turbo etc
Has a large member
Having a clear out. all items are plus postage or can be collected.
Diesel Mk4 escort gearbox complete with S2 RS turbo driveshafts, cradle, mounts, speedo cable etc (everything you see!) £110
S2 cvh rocker cover £9
S2 charge pipe £9
S2 Escort RS turbo loom couple plugs have been cut off if i recall. fuse box is mint and not melted like most! fuel ecu also included £49
S2 rs turbo inlet sandwhich £10
Pulley £10
washer bottle (the marks are glue, it will clean up well) £10
T3 turbo. has play needs rebuild. complete with everything you see so perfect for exchange/rebuild. £40
CVH starter motor £14
mounts £5 SOLD
front arch liners. bit of tyre rubbing but will clean up well £35
S2 charge pipe £9
Pulley £10
mounts £5 SOLD
big_Rad
Sep 15, 2017 09:36 AM
Matt Baxter
Sep 16, 2015 08:30 PM
muz
Aug 16, 2015 12:57 PM
