Sierra Cosworth 2wd Parts
Old Apr 1, 2013 | 04:28 PM
Glenn H's Avatar
Glenn H
Default Sierra Cosworth 2wd Parts
I've got a few parts from my own working car that I'm replacing on my restoration / rebuild.
All prices included UK 48 hour Sign for service in the UK.
I will upload pictures or a link to my photbucket ASAP.
If Not Sold Will Be Listed On Ebay In At The End Of The Week.
Standard lv6 Ecu £100.
Standard Cams with Pulleys (Ebay Now)
Standard T3 Turbo and Manifold working but has play (Ebay Now)
Rocker Cover (Ebay Now)
Disturbiter complete with 8mm Red HT Leads, cap and Group A Coil £75.
Standard Fuel Pump £20.
Rear Brake Calipers £40.
Front Calipers With Brand new pads and Cross drilled and Grovered Disks Not Even Used £135.
Rear Beam Missing Rear Brakes £120 Pallet Service Included.
Lower Arms New And Poly Bushed less than 700 miles ago £55.
Old Apr 3, 2013 | 04:38 PM
rsturbo1's Avatar
rsturbo1
Would you sell front brake pads separate.
Old Apr 3, 2013 | 06:29 PM
MARKYMARKONE's Avatar
MARKYMARKONE
Hi mate
Ive sent you a pm
Mark
Old Apr 4, 2013 | 09:23 AM
Glenn H's Avatar
Glenn H
i picked this up yesterday may break or sell complete depends after M.O.T tomorrow.
Old Apr 4, 2013 | 05:21 PM
rsturbo1's Avatar
rsturbo1
I have no pm mate
Old Apr 4, 2013 | 07:47 PM
jamie's's Avatar
jamie's
if you brake the white 1, how much for the turbo?
how much is the turbo on ebay?
Old Apr 4, 2013 | 09:22 PM
mechanic28's Avatar
mechanic28
you got any pics of the brakes matey?
Old Apr 4, 2013 | 09:30 PM
bigdel's Avatar
bigdel
does the radiator header tank have the water level sender, or is the hole just blanked off?
Old Apr 5, 2013 | 07:43 AM
tessatony's Avatar
tessatony
if you break can i have first dibbs on the turbo heat shield pls
Old Apr 7, 2013 | 08:49 PM
bigdel's Avatar
bigdel
Got a header tank now.
If you break it, how much for the turbo to header tank coolant return - both bit, alloy & rubber hose
Old Apr 8, 2013 | 08:14 AM
cossiekevin's Avatar
cossiekevin
hi pal, i see the white one is up for breaking on ebay, i sent you a message on there but can i have first dibs on bonnet please?
cheers
Old Apr 9, 2013 | 08:51 AM
Longdog3004's Avatar
Longdog3004
Still got the brakes, calliper s and discs mate?
Old Apr 9, 2013 | 11:35 AM
joffy's Avatar
joffy
SLOW LEARNER
What injectors does it have?
Old Apr 10, 2013 | 02:52 PM
Rob Virgo's Avatar
Rob Virgo
Looking for cosworth Sierra three rear s/s braided brake lines
Old Apr 21, 2013 | 08:39 PM
B16's Avatar
B16
Hi Glenn
I'm interested in the Turbo heat shield
CheeRS
Paul
Old Apr 21, 2013 | 08:49 PM
doga-ot's Avatar
doga-ot
Bud if this has koni front adjustables how much cheers
Old Apr 22, 2013 | 04:57 PM
cossie891's Avatar
cossie891
Is this one breaking mate
Old Apr 23, 2013 | 06:54 AM
longman's Avatar
longman
How much for the Curly PAS hose?
Ad
charliecosworth
Aug 19, 2015 02:00 PM
cossie4x4
Aug 14, 2015 06:29 PM
155lee
Aug 14, 2015 11:21 AM
Aug 14, 2015 07:29 AM
Old ford
Jul 31, 2015 06:50 AM
