Escort Cosworth LUX 500 BHP Breaking AP 6 Pots 355
Mallard Green Lux With Full Leather, Registered 1994, 67000 miles, HPI Clear, All original panels,
Engine Spec -
GT35 TURBO, GT TURBO MANIFOLD, TURBONETICS WASTEGATE, OMEX 710 ECU, 8 INJECTOR WIRING LOOM, COSWORTH FORGED PISTONS WITH LARGE VALVE CUT OUTS, HEAD IS PORTED AND POLISHED, LIGHTENED + BALANCING SHOT PEEN KNIFE EDGE CRANKSHAFT, ARP BIG END BOLTS, 200 BLOCK MACHINED FOR 10 STUDS, 4X4 WATER PUMP MODIFIED FOR THIS, PIPER DOUBLE VALVE SPRINGS, BRONZE VALVE GUIDS, HKS FUEL PRESSURE REGULATOR, KENT CAMS, SWEDISH PLENUM, WRC INLET MANIFOLD, 8 803 DARK GREEN INJECTORS, 3 BAR MAP SENSOR, ALCON 6 PADDLE CLUTCH, GROUP A FUEL PUMP.
New AP six pot brakes with 355x32mm discs, Tarox grooved rear Discs, Poly Bushed Throughout, Stainless Steel Exhaust, large Alloy Intercooler And Radiator, Swril Pot, Alloy Header Tank, Alloy Power Steering Bottle, PJ Motorsport Blue Hoses, Group A Strut brace, Koni Suspension, Vibra tech Engine Mounts, 18" Super T Alloys With 2 New Tyres. Greedy Profec B-Spec 11 Controller.
Road Tax April 2013
MOT August 12013
All parts Available.
Engine Spec -
Road Tax April 2013
MOT August 12013
