swapping ecu's
Old Mar 27, 2013 | 05:43 PM
rs53ash's Avatar
rs53ash
Default swapping ecu's
Just wondered is it just a straight swap or is there other things needed?
Cheers.
Old Mar 28, 2013 | 12:10 AM
CosworthGuy's Avatar
CosworthGuy
3dr Cosworth owner
Not quite a straight swap. Physically yes but in reality no. At the very least you will need your old ecu read for the cars transponder codes and then when the new ecu fitted they will need to programmed in or otherwise your cars immobiliser will stop it starting. Or if you cant get your code off old ecu you'll also need the chip out the other cars key and I think that will then work it
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
griffo69
Oct 4, 2015 11:58 AM
cossie brad
Sep 29, 2015 02:38 PM
DixieTheKid
Sep 14, 2015 09:04 PM
grishenko45
Sep 9, 2015 12:58 PM
