Final Escort Cosworth Parts, OFFERS available on everything... - 04/07/2013
Old Mar 24, 2013 | 10:00 PM
FletchCossie's Avatar
FletchCossie
Default Final Escort Cosworth Parts, OFFERS available on everything... - 04/07/2013
Please note: All parts prices are without postage and if paying via Paypal please pay as a gift to FletchCossie@googlemail.com
Also Note: All parts are on first come first served basis and will not be held for anyone without a deposit.
Also Note: ALL PARTS ARE PICTURED BELOW AND ARE FOR ESCORT RS COSWORTH UNLESS STATED
Drivetrain and under the car:
GGR straight through exhaust system (No cat, 3 inch bore and oval end) - £250
Power steering pipe from top of pump to lower port on tank - £10
Escort Cosworth washer bottle with level sensor (Snapped top bracket, but Ive patched it up to not leak and has been full on the car for 6 months. It also has an extra hole drilled for another washer pump which I used for an intercooler spray) - £20
Rear suspension spring rubber mounnts - £10 Pair
Driveshaft mounting bolts (Full set) - £15
Petrol tank (No pump or sender) - £30
Front wiper motor/linkage - £20
Anthracite bonnet stand (Slight paint damage where goes into gromit) - £10
Bonnet stand gromit - £5
Canister from inside drivers wing - £10
Exhaust bracket from gearbox (Believed to be from a Saph Cossie) - £15
Bodywork:
Note: All panels will require painting, but are Mallard Green.
(Pictured below)
Big turbo wing mirrors (One has replacement stick on glass) - £30
Bonnet side fixings to chassis - £5
Interior:
(Pictured below)
Front speaker adaptors for bigger speakers - £10
Electric window interior covers (Drivers side lower bracket snapped, but comes with working switch) - £5 each
Interior door opener covers - £10 pair
Interior roof light - £10
Momo Steering wheel - £30
Escort Cosworth big turbo airbag steering wheel boss (With air bag wire to turn light off and modified horn ring) - £40
Indicator column stalk (New from Fords 6 years ago) - £30
Dash (Holes for alarm drilled, shown in pictures) - £80
Lower column surround - £10
Upper column surround (Hole for alarm LED) - £10
Fuse box cover (With fuse remover tool) - £10
Passenger window regulator - £20
Genuine Ford round terminal battery (Perfect fit for Cosworth) - £15
Heated front window switch - £10
Rear fog light switch - £10
Electric window switch £15 pair
Door pin switches - £10
Relay Assembly Door lock control - £10
Fuel pump cut off/Inertia switch - £10
Throttle pedal - £10
Air bag control module - £10
Passenger door wiring - £15
Drivers door wiring (Cut for speaker fitting) - £15
Please contact me (Steve) on 07732 872 122 or via PM for anything you require. Please leave a voicemail or text if I am unable to answer and I will get back to you
Last edited by FletchCossie; Aug 26, 2013 at 10:37 AM. Reason: Sold parts moved with pictures deleted - ALL ITEMS OPEN TO OFFERS - 26/08/2013
Old Jun 5, 2013 | 02:41 PM
FletchCossie
Deleted
Old Jun 5, 2013 | 07:41 PM
FletchCossie
Deleted
Old Jun 8, 2013 | 10:47 AM
Rozvor's Avatar
Rozvor
PM about Fuel rail - £20
Old Jun 8, 2013 | 06:23 PM
FletchCossie
Pm replied to, thanks mate
Old Jun 10, 2013 | 08:14 PM
FletchCossie
Deleted
Old Jun 10, 2013 | 08:19 PM
FletchCossie
003 fuel pump and sender SOLD
Fuel rail sold pending payment
Old Jun 12, 2013 | 12:20 PM
rob_manu's Avatar
rob_manu
hi bud. have you still got the clock/dials light dimmer unit still.?
Old Jun 12, 2013 | 01:04 PM
FletchCossie
Do you mean the dimmer switch on the lower dash panel under the steering column. I'm sure I do still have it as I dont remember it selling
Old Jun 12, 2013 | 01:07 PM
FletchCossie
Alternator SOLD
Fuel Rail SOLD
Old Jun 12, 2013 | 01:13 PM
rob_manu's Avatar
rob_manu
yeah thats the one, and the surround if you have it.? I'm building an incomplete project so presume the plastic it's located in is missing too
Old Jun 12, 2013 | 02:06 PM
FletchCossie
I will have a look for it and let you know the surround is the lower dash panel or are you thinking of a Saphire Cossie?
Old Jun 12, 2013 | 02:08 PM
rob_manu's Avatar
rob_manu
thanks mate. it is for escort cos
Old Jun 13, 2013 | 05:47 PM
peteh's Avatar
peteh
That engine was too cheap!!
Old Jun 13, 2013 | 09:54 PM
FletchCossie
Thanks mate. I'm having trouble with the buyer anyway so it's still for sale, saved me a £75 eBay fee Minimum I will take is £3000 and it won't be going back on eBay
Old Jun 14, 2013 | 06:13 AM
cossiedad's Avatar
cossiedad
I see the same zero rated buyer won both engine and exhaust. Does that mean the exhaust is still for sale too? It's not quite what my mate wants but he's that desperate for a system he was willing to buy it. What's your bottom price for it?
cheeRS
Old Jun 14, 2013 | 07:09 AM
peteh's Avatar
peteh
Oh crap sorry to hear that, usually the way on that site now unfortunately.
Old Jun 14, 2013 | 08:23 AM
FletchCossie
CossieDad, you have PM.
Pete, not much can be done mate, but saves the engine going cheap
Door rubber seals SOLD
Sunroof motor with switch SOLD
Old Jun 30, 2013 | 08:31 PM
FletchCossie
DEPOSIT TAKEN ON ENGINE
Front anti roll bar - SOLD
Breaking ABS unit pump - SOLD
Brake distributor - SOLD
Rear light bulb holders - SOLD
Electric sunroof panel - SOLD
Anti Lock Brake Controller - SOLD
Drivers door lock mech and handle - SOLD
Old Jul 4, 2013 | 12:14 PM
FletchCossie
The first post is now accurate with all items that are left and Im open to offers on everything now to clear them from my garage
Old Jul 5, 2013 | 05:11 AM
rob_manu's Avatar
rob_manu
hi. would you take £15 posted for window switches and dash fuse cover.? if so I'll have them. thanks
Old Jul 5, 2013 | 11:47 AM
FletchCossie
Will do them £20 delivered mate PM me your address and please pay as a gift via Paypal to fletchcossie@googlemail.com I can package them up and post tomorrow morning if you pay today
Old Jul 13, 2013 | 08:48 PM
rob_manu's Avatar
rob_manu
hi mate. have you still got the plastics that cover the top bolts on the seatbelts.? if so how much posted
Old Jul 14, 2013 | 10:41 AM
FletchCossie
Sorry mate, I only have what is listed above for sale.
Old Aug 26, 2013 | 10:39 AM
FletchCossie
First post updated with all sold parts removed. I also have a brand new front passenger side wing mould for a Sierra Cosworth on ebay:
http://www.ebay.co.uk/itm/2811553489...84.m1555.l2649
Vincereese
Jun 1, 2023 09:14 AM
jessie_rs
11
Jun 3, 2019 04:57 PM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
Old ford
Jul 31, 2015 06:50 AM
