1991 Toyota Hilux Surf may consider swap/px
Old Mar 24, 2013 | 09:34 PM
barclay03's Avatar
barclay03
Default 1991 Toyota Hilux Surf may consider swap/px
1991 Toyota Hilux Surf 2.4TD Auto
182,000kms (roughly 113,000 miles)
MOT - 29/11/2013
Tax - 31/03/2013
Recaro interior
Rear parcel shelf
Toyota wind deflectors
2 Inch Suspension lift
Snorkel
31x10.5x15 BFG A/T Tyres (All with tons of tread left)
Head replaced by a previous owner
Roughtrax starter motor kit fitted
Electric sunroof, windows etc
The truck drives spot on. Auto box is all fine with no bad noises, overdrive etc working fine. 4WD all working fine also, it’ll take it you damn near anywhere you want it to!
Just been serviced (09/03/2013). Handbrake cable not long been replaced, along with brake pipes, anti roll bar links and bushes, and diff oils changed. Previous owner replaced the exhaust last year and also replaced the brake master cylinder and front brake pads and discs (tons of life in them). Refurbished fuel pump fitted Nov 2011. The rear shock absorbers were replaced in Nov 2011, standard ones were fitted so only the front retains the adjustable shocks. Intake elbow at turbo hose replaced Feb 2013.
Bodywork wise, it isn’t too bad. There is a little bit of damage to passenger side front arch, also to rear passenger door, but generally clean for a 22 year old truck. Underside all looks solid, just needs a brush down and paint/undercoat if you're that way inclined. I’ve also removed the side steps as I prefer the truck without them.
Bad bits:
- Air con disconnected
- Slight blow from the exhaust (likely just a gasket)
- Crack on passenger side arch as mentioned
- Hole in rear seat, small hole on passenger seat and usual bolster wear on driver’s seat
- Usual rust spots comming through on front bumper, rear bumper has been removed and replaced with tubular
Any inspection welcome and any questions feel free to ask.
Truck is located in Glasgow and I’m looking for £1300 for it. Can also be taxed at buyer’s expense.
Ill get more pics once the rain is off, and off seats etc.
Before side steps and sin visor were removed - just to show passenger side and rear until i upload the other pics
SmudgerByName
52
Jul 28, 2016 06:14 PM
shoppel
Ford Escort RS Cosworth
11
Sep 28, 2015 04:07 PM
gjh
Aug 5, 2015 04:21 PM
Big_Psi_4x4
Aug 9, 2005 12:07 AM
M7 COS
20
Feb 24, 2005 05:40 PM
